    Mercedes calipers on starquest? hmmm
    83starpower
    By 83starpower,
    I work for an independent mercedes repair shop.  So im constantly coming across free stuff. For instance, i replaced two bosch fuel pumps on an 89 560 sL mercedes.  The pumps were perfectly good, but being that most people that drive mercedes have got the bucks, the lady wanted it done for "safety" reasons.  Anyways the braking systems on mercedes have always been very good. They have to be, to stop a heavy german tank. I think that it might be possible use theyre calipers.  I have two double pi
    More Engine info for archiving
    Tim_C.
    By Tim_C.,
    Well, I just got the TEP Race Prepped Crankshaft in the block. Went to pick up the block and the machinist had it sitting on the line hone machine. It is a long (4' or so) rod with stones all along the sides.  We split hairs to .0005".  That's how close to perfect it came out.  It was so far out of spec that it would not have lasted long, and Steve at TEP says they line hone all of them now because they found that out.  Just about all of the 2.6's are out enough to need the honing even if they
    Fidenza Clutch Adjustment
    heefner
    By heefner,
    Memorial day weekend I installed a resurfaced 88 flywheel and new ATC clutch and pressure plate into my 86.  When I started it up and tried to put it in gear I had to jam the pedal into the carpet to disengage the clutch.  As soon as I took a tinny bit of  pressure off the clutch it would  engage.  I thought it was the flywheel (too much taken off and therfore too skinny) so I bought the fidenza aluminum flywheel and had shipped 2 day air so I could put it in Sat.  The same thing happend.  Turns
    CERAMIC BRAKE PADS
    Sam
    By Sam,
    Anyone using ceramic brake pads ?  Where did you get them ?   Thanks, Sam
  • Today's Birthdays
    1. speedoholic
      speedoholic
      (40 years old)
    No members to show
