- 12 replies
- 908 views
- 467 views
- 417 views
- 438 views
If Going TO PF14 Or trying too
By Tman,
Ok ive been thinking lately how can I give back to the club/members and I have come up with this.. There has been a few times in the past that me going or not being able to go to pf was as little as a 100.00 dollars So here is what im wanting to do if you coming to pf would be easier with a extra 100.00 or if you would be able to come because of 100.00 then leave your name in this thread and I will pick a name a random and eiher paypal u before hand or send u a money order or cash at pf
Control relay can u remove thru glove box??? 86
By markhansenconquest,
Thats the the last thing I have to check in 86 ignition system.....It will start on starting fluid only...After warmed up it will start sometimes,but most of the time it needs S/Fluid to start again...Checked with noid light...no flash on light ( both ways + - ) when cranking ...timing is 10 btdc....Tried good ignitor from my dads car......Gas pressure is 38 psi .. Changed all 3 filters.... On page #14-43 86. FSM It shows control relay and how to check it........Car Is not getting crank
Thats the the last thing I have to check in 86 ignition system.....It will start on starting fluid only...After warmed up it will start sometimes,but most of the time it needs S/Fluid to start again...Checked with noid light...no flash on light ( both ways + - ) when cranking ...timing is 10 btdc....Tried good ignitor from my dads car......Gas pressure is 38 psi .. Changed all 3 filters.. Tryed diffrent 86 ecu. (same) . On page #14-43 86. FSM It shows control relay and how to check
1987 mitsubishi starion/chrysler conquest 2.6 turbo tsi - $3 (chicago)
By NikoFab,
http://chicago.craigslist.org/chc/cto/4520723705.html http://images.craigslist.org/00O0O_hnCIu6Y0A5x_600x450.jpg http://images.craigslist.org/00O0O_hnCIu6Y0A5x_50x50c.jpghttp://images.craigslist.org/01414_43ORWbtkBZh_50x50c.jpghttp://images.craigslist.org/00H0H_64gSdBC73lj_50x50c.jpghttp://images.craigslist.org/00O0O_4bYXyDP8V5c_50x50c.jpghttp://images.craigslist.org/00q0q_cptHKD3Jopt_50x50c.jpghttp://images.craigslist.org/00101_5XtM9BVz3lc_50x50c.jpghttp://images.craigslist.org/00S0S_2Nkczeq
