- 8 replies
- 1327 views
- 384 views
- 16 replies
- 983 views
- 1 reply
- 466 views
Power steering leak fix?
By pcristquester,
My new to me 88 Starion has a bad leak of steering fluid where the box resides on the driver side of engine bay. 99% sure the PO did not use the correct fluid. It's totally clear fluid, not red like the ATF I use in my quest. Can I drain and flush it out and refill with ATF and possibly get the seals to hold, or does the wrong fluid destroy the seals? What would I likely need to replace in this situation? Thanks in advance for any help
Brake master cyl banjo bolt and block
By theboyo19,
I lost mine in the move with my car. I would appreciate it if someone would hook me up with the banjo bolt and Dist block? from the end of the master cylinder? Thanks
FLYWHEEL HELP
By elkuko87,
Hi I am new at this web forum I was told when I took off my flywheel that when I re install will need to index why there is only one way that this goes on when you match up the bolts can any one help me with this also need bolts I lost one thinking about arp need input I am at a stand still know
right taillight connector
By CarlosFley,
Soooo in the time that my car was sitting at the previous owners house water apparently got into the right taillight housing and corroded the bulb connections. I believe this might be the cause for my electrical gremlins. If you happen to have the CONNECTOR itself NOT the housing, I'd be highly interested in acquiring it. Shipped to 94590. Text me if ya do cuz it'll be much faster and smoother that way 7072673473
