Fanta Posted October 15, 2008 Report Share Posted October 15, 2008 Can ARP headstuds be installed with the engine in the car ( head removed of course ) or not really. Link to comment Share on other sites More sharing options...
TexasQuest Posted October 15, 2008 Report Share Posted October 15, 2008 I don't see why not? Link to comment Share on other sites More sharing options...
Mix_67 Posted October 15, 2008 Report Share Posted October 15, 2008 Sure can, did mine two weeks ago. Depending on what you all you remove your gonna need someone there to help you get it snaked around everything and lined up. Link to comment Share on other sites More sharing options...
Indiana Posted October 16, 2008 Report Share Posted October 16, 2008 not if its a motor you expect to pull out an old head bolt and install an arp, you must remove the head, clean the holes and remove all the dirt and oil or lube from what came out of the bolt holes or you'll screw in the new studs, and you must either oil or put the moly lube on the threads they don't go in dry, then as you tighten them down the muck oozes up out of the bolt hole and gets to seep in under the headgasket -ruining it its easier to put the studs in after you have the head on but you have to be careful about the oil on the threads that go into the block because you know that it IS going to come up and ooze out from the threads of that stud when you tighten it down with your fingers and where does it go? It just lays there in contact with the headgasket that isn't sealed... Link to comment Share on other sites More sharing options...
Minagera Posted October 16, 2008 Report Share Posted October 16, 2008 It is very simple. Infact, if you are really freaking good you can install them with the head on, if you doing it one by one. Link to comment Share on other sites More sharing options...
knightrider56 Posted October 19, 2008 Report Share Posted October 19, 2008 do the ARP studs have to be retightend after driving the car a few miles Link to comment Share on other sites More sharing options...
