89PalermoSHP Posted September 26, 2008 Report Share Posted September 26, 2008 I cant seem to find something specific. Is there a brand better than another? Link to comment Share on other sites More sharing options...
scooterh72 Posted October 14, 2008 Report Share Posted October 14, 2008 I cant seem to find something specific. Is there a brand better than another? I would like a good source as well. Link to comment Share on other sites More sharing options...
RamAirResearch Posted May 8, 2009 Report Share Posted May 8, 2009 I was able to find a replacement T/C here transmissionpartsusa.com They can also have them sent out and rework the internals on them for higher stall applications but thatis a bit costly a few hundred extra in the end it may be a bit cheaper but definately alot more benificial as faras shiuft kits/torque converters,Valve bodies ETC. to make an adapter for the use of a different/domestic auto trans,i have the pattern for mopar SB V-8 904/727/A500OD & A518 OD,for the bell houseingand for the spacer for the crank ,useing the Chrysler flywheel and a brass drift to hold in back of the existing holes wels the old crank bolt circle holes closed,grimnd it smooth after you are dont and useing the SQ flywheel as a pattern redrill the new center anchoring hole and bolt circle,i can mail the patterns if you are interested,cannot e mail them because you cannot print them, in the correct size Link to comment Share on other sites More sharing options...
Shelby Posted May 30, 2009 Report Share Posted May 30, 2009 you might try ...level10 for a convertor Link to comment Share on other sites More sharing options...
89PalermoSHP Posted June 1, 2009 Author Report Share Posted June 1, 2009 you might try ...level10 for a convertor they dont give those trannys away! i wonder if the $2500 would be worth it? would it last as long as 2 rebuilds? http://www.levelten.com/SearchResults.asp?...mp;Redirected=Y Link to comment Share on other sites More sharing options...
Shelby Posted June 13, 2009 Report Share Posted June 13, 2009 they don't give any tranys away Link to comment Share on other sites More sharing options...
AutoBodyGod Posted October 17, 2009 Report Share Posted October 17, 2009 I bought a rebuild kit & converter for my L4N71B about 10 years ago from Dacco Transmission Parts 1987 1991 DODGE CONQUEST L4N71B, E4N71B G, L, ZB Torque convertor part# DA14 Link to comment Share on other sites More sharing options...
Shelby Posted April 3, 2010 Report Share Posted April 3, 2010 another option , checl with your local tranny shops,, often some do convertor rebuilds on site,,and often can modify the stall rpms as they do them Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted September 6, 2010 Report Share Posted September 6, 2010 Transtar DA8 for 87-DA14 for 88+ Link to comment Share on other sites More sharing options...
