xavier_87conquest Posted January 5, 2008 Report Share Posted January 5, 2008 IM REBUILDING MY MOTOR IM LOOKING FOR A NEW OIL PUMP BUT EVERWHERE I GO THEY GAVE ME THE SAME OIL PUMP. I WORK IN PEP BOYS AND WE SELL THE SAME. I LOOK OVER STARION-CONQUEST ALL YEAR, MAZDA 2.6, MONTERO 2.6, DODGE 2.6, PLYMOUTH 2.6, THEY ALL USE THE SAME OIL PUMP. THE OIL PUMP I NEED HAVE A HOLE IN THE BOTTOM FOR THE OIL PICK UP TUBE, THE ONE I FIND DONT HAVE THAT. WHERE I CAN GET THE OIL PUMP I NEED? IF POSIBLE THE HIGH VOLUMEhttp://i216.photobucket.com/albums/cc221/xavier_87conquest/58bc_1-1.jpgthis is the one i dont need Link to comment Share on other sites More sharing options...
jwrape Posted January 5, 2008 Report Share Posted January 5, 2008 ASk Dad for it. He's got the right one http://www.enginemachineservice.com/conquest.htmlhttp://www.enginemachineservice.com/26oilpump.jpgOEM Oil Pump. Turbo application only $162.99 Link to comment Share on other sites More sharing options...
GCNTSi Posted January 5, 2008 Report Share Posted January 5, 2008 Yeah don't try to use that NA one, I learned the hard way, it doesn't work. -GCNTSi. Link to comment Share on other sites More sharing options...
xavier_87conquest Posted January 6, 2008 Author Report Share Posted January 6, 2008 YEAHH THATS THE ONE. YOU THINK THE STOCK VOLUME OIL PUMP ITS GOING TO WORK FINE FOR MY MODED ENGINES. OR YOU RECOMEND THE HIGH VOLUME Link to comment Share on other sites More sharing options...
Blind_Drifter Posted January 6, 2008 Report Share Posted January 6, 2008 Stock one is good. Removed balance shafts add some oil pressure. Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted January 6, 2008 Report Share Posted January 6, 2008 There's no such thing as a "high volume" pump other than the stock turbo pump. Link to comment Share on other sites More sharing options...
xavier_87conquest Posted January 6, 2008 Author Report Share Posted January 6, 2008 TOP END PERFORMANCE sells a "high volume" oil pump for $229.00, stock one for $199.00 i think is the same pump. they say is high volume just to get more money for the same pump. Link to comment Share on other sites More sharing options...
alostsoul Posted January 7, 2008 Report Share Posted January 7, 2008 TOP END PERFORMANCE sells a "high volume" oil pump for $229.00, stock one for $199.00 i think is the same pump. they say is high volume just to get more money for the same pump. i have the pump your speaking of, and honestly cant remember if i saw any difference in the guage when the car was running than before with the stock unit. Link to comment Share on other sites More sharing options...
89PalermoSHP Posted January 7, 2008 Report Share Posted January 7, 2008 I got the stock replacement when I rebuilt my motor and I sit at about 1/2 at idle and just over 3/4 under load. I dont have an aftermarket gauge so take it for what its worth I guess. I do wish I went with a different one but I wont get into that. 8) Link to comment Share on other sites More sharing options...
jwrape Posted January 7, 2008 Report Share Posted January 7, 2008 I think with the BSE you will have plenty of oil pressure with the stock replacement. It has a good track record for giving the motor what it needs when in good operational state, i.e. new. Link to comment Share on other sites More sharing options...
Indiana Posted January 8, 2008 Report Share Posted January 8, 2008 when you order parts,where do they ship in from? can you get parts from Japan? Link to comment Share on other sites More sharing options...
89PalermoSHP Posted January 9, 2008 Report Share Posted January 9, 2008 mitsubishiparts.com is the cheapest place to buy the stock replacement oil pump. its never really fast so if you have 2-3 weeks to spare you can save some ching. if your in a hurry contact randy(dad) at enginemachineservice.com Link to comment Share on other sites More sharing options...
Guest Posted January 9, 2008 Report Share Posted January 9, 2008 The STOCK turbo oil pump is "high volume" pump, that is compared to the NA one. The NA pump has less oil pressure than the turbo oil pump, hence "high volume." :wink: Link to comment Share on other sites More sharing options...
Nick7 Posted January 10, 2008 Report Share Posted January 10, 2008 ask dad or randall, hes got some and ships fast. they r OEM what u need. Dont buy junk ones from autozone or parts houses. Link to comment Share on other sites More sharing options...
xtremeboost Posted January 11, 2008 Report Share Posted January 11, 2008 stock pump has been taken up into the 800hp range - worked good !!!! Link to comment Share on other sites More sharing options...
Indiana Posted January 11, 2008 Report Share Posted January 11, 2008 The NA pump has less oil pressure than the turbo oil pump, hence "high volume." Only if the low volume pump is on a pre1984 truck motor and that pump isn't available any longer is it? the gears are what determines the oil flow and the relief valve dumps excess pressure above 3000rpms and they are both the same the only difference in the two pumps is the hole in the backing plate to suck in the oil or the bottom of the front cover to suck in the oil and the oil in both ends up being drawn into the gears through the same curved molded passage but both have the output from the gears going out the same hole and feeding the engine the same way with the same pressures and flow rates if you want to see pictures and more details from the manual pages go about 2/3 way down this page: http://www.b2600turbo.com/Oil%20Pumps.htm Someone should be making a new pickup tube so we can use the cheaper pump don't you think? The other one won't be available forever and there are many more n/a engines out there. I have some new thin pump front covers and backing plates and a set of used thin gears I will add in later Link to comment Share on other sites More sharing options...
MontyTSI Posted January 14, 2008 Report Share Posted January 14, 2008 i used a sealed power turbo pump and it gave great results (never below 3/4 on a stock gauge). Sealed power calls it high volume because its higher volume than a standard NA pump not that its more volume than a standard turbo pump. I used it only because i (my dad) has long time friends at sealed power that hooked me up for very little. I agree the stock pump is plenty good for any of us and most likely exactly the same as a new sealed power unit. Link to comment Share on other sites More sharing options...
tsiconquest88 Posted January 21, 2008 Report Share Posted January 21, 2008 supposedly TEP claimed thiers had a larger gear than the turbo oem one for that 229 dollar pump they had. may or may not have been true but either way u dont need more flow they pump plenty good enough cus if u have clean oil holes to the bearings and clean squirters, etc. there should be no problems, and the best way for assuring all that is by driving your CAR lol people get these cars that sat for years and all and expect a perfect engine, most likely not for long lol. the oil holes are gum'd up etc. oil goops up in there, especially if it was a person that didnt change oil that reallt gunks an engine up then it sat, forget that motor its gonna be torn apart in a month or sooner. Link to comment Share on other sites More sharing options...
Guest Posted January 23, 2008 Report Share Posted January 23, 2008 i used a sealed power turbo pump and it gave great results (never below 3/4 on a stock gauge). Sealed power calls it high volume because its higher volume than a standard NA pump not that its more volume than a standard turbo pump. I used it only because i (my dad) has long time friends at sealed power that hooked me up for very little. I agree the stock pump is plenty good for any of us and most likely exactly the same as a new sealed power unit. When I was a noob, I bought into the whole "high volume" oil pump claimed by TEP. Since I live so darn close to them and can literally ride my bicycle to theri shop, I decided to check it out in person. I talked to their people, I got the "we don't have em in stock, but check back with us in a week or so", I kept getting that same story. After finding that their answers to my questions didn't pan out, I knew I was being bamboozled. High volume :roll: Stick with a stock turbo pump, more than enough. Link to comment Share on other sites More sharing options...
macrophage Posted March 19, 2008 Report Share Posted March 19, 2008 There's no such thing as a "high volume" pump other than the stock turbo pump. Thats good info. Link to comment Share on other sites More sharing options...
emagdnim Posted March 20, 2008 Report Share Posted March 20, 2008 Just listen to indiana, you will not find better information. Link to comment Share on other sites More sharing options...
Whiplash Posted March 20, 2008 Report Share Posted March 20, 2008 Just listen to indiana, you will not find better information. X2 Yes the guts are the same. I got both pumps. The gears are the same. Just that the turbo oil pump has an alloy front cover, with the pick-up on the bottom. I'm sure you can use the NA pump with the NA oil pick-up. But I'd rather not have my oil going through a hot engine like in the NA pump. Link to comment Share on other sites More sharing options...
emagdnim Posted March 20, 2008 Report Share Posted March 20, 2008 So, you're saying the 2 inches it has to pass threw is a heat soaking problem? Link to comment Share on other sites More sharing options...
Whiplash Posted March 23, 2008 Report Share Posted March 23, 2008 So, you're saying the 2 inches it has to pass threw is a heat soaking problem? I must have a differant block than you. Mine is something like 8 or 10 inches. I'll measure it later today. Link to comment Share on other sites More sharing options...
emagdnim Posted March 23, 2008 Report Share Posted March 23, 2008 I must have a differant block than you. Mine is something like 8 or 10 inches. I'll measure it later today. That's not going to make a difference on my car... and I doubt its going to be a big deal on a street car with the factory oil cooler either. Link to comment Share on other sites More sharing options...
