Ryan_V Posted November 4, 2007 Author Report Share Posted November 4, 2007 I supposed I could've done that, but I wanted to make sure I had proper torque in case there's anything wrong with the motor. I don't want the engine rebuilder saying I didn't torque it properly. Knowing what I know now. I don't foresee any issues with the motor. Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted November 12, 2007 Author Report Share Posted November 12, 2007 I would say this sucker is ready to drop in. The engine leveler is worth it's weight in gold. http://img.villagephotos.com/p/2003-5/202062/RDDPQ-111107004.jpg I also got the Stedabani short shifter put together. http://img.villagephotos.com/p/2003-5/202062/UYGKV-111107001.jpg Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted November 18, 2007 Author Report Share Posted November 18, 2007 http://img.villagephotos.com/p/2003-5/202062/ITWMI-100_1073.jpg After Oil pan and Tranny cover sealed uphttp://img.villagephotos.com/p/2003-5/202062/IKSPC-100_1074.jpg Next, the 89 SHP Tsi get's a motor! Right now..it's my workbenchhttp://img.villagephotos.com/p/2003-5/202062/CDUVC-100_1075.jpg Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted November 18, 2007 Author Report Share Posted November 18, 2007 Not as hard as I thought it'd be! This was my first time stabbing the motor and trans together.http://img.villagephotos.com/p/2003-5/202062/MYCPE-100_1078.jpg Shortly after this it started raining on me!!!! :evil: http://img.villagephotos.com/p/2003-5/202062/DJXVA-100_1079.jpg Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted November 20, 2007 Author Report Share Posted November 20, 2007 I got the engine in. I mucked up the motor mount threads, and thanks to a great idea from Tim. I used a die to retap the threads. I found that a 10mm 1.25pitch die worked like a charm. I was able to tap the threads with the engine still in the car. So now, I can move forward! :wink: Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted November 21, 2007 Author Report Share Posted November 21, 2007 Getting there! All I have left to do now is alternator,radiator,finish tranny mount,bolt up the stedabani shifter,bleed brakes EDIT: forgot to set date on the camera! http://img.villagephotos.com/p/2003-5/202062/IMGP0558.JPG http://img.villagephotos.com/p/2003-5/202062/IMGP0555.JPG http://img.villagephotos.com/p/2003-5/202062/IMGP0556.JPG Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted November 29, 2007 Author Report Share Posted November 29, 2007 Still haven't had the time to finish it off. I need to rebuild a distributor for it and oil-prime it and that's it. http://img.villagephotos.com/p/2003-5/202062/IMGP0569.JPG Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted December 1, 2007 Author Report Share Posted December 1, 2007 It's running! Not one leak, great oil pressure and it doesn't overheat at all! Man, it drives fabulous! The suspension and front end are super tight. The Stedabani shifter is perfect for this car too! I still need to bolt the sway bar on,bleed the steering box and a whole bunch of other little things before it's really ready for the street! :roll: http://img.villagephotos.com/p/2003-5/202062/IMGP0571.JPG My lil' helper Lukehttp://img.villagephotos.com/p/2003-5/202062/IMGP0575.JPG Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted December 1, 2007 Author Report Share Posted December 1, 2007 So to recap this ordeal for you- 1. I bought this car 3 yrs ago and it's sat ever since. 2. I installed a supposed low mileage Jasper engine back in August 3. Little did I know the thrust bearing had started to fail 4. The car wouldn't go into gear because the entire crank would move forward when the clutch was depressed. Hence the thrust bearing failure. 5. I took the motor out and had it completely rebuilt. 6. Its now installed and has great oil pressure, runs smooth, doesn't overheat. It's been a long time coming for this car. Ryan I Quote Link to comment Share on other sites More sharing options...
angryhero46 Posted December 1, 2007 Report Share Posted December 1, 2007 Nice work.It looks real good to! Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted December 1, 2007 Author Report Share Posted December 1, 2007 Thanks! Quote Link to comment Share on other sites More sharing options...
Dad Posted December 2, 2007 Report Share Posted December 2, 2007 Nice job Ryan, Enjoy! dad Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted December 2, 2007 Author Report Share Posted December 2, 2007 You, Tim and Shelby really helped me out a lot on this one! EDIT: Gotta send thanks out to Indiana as well! Thanks alot, Ryan Quote Link to comment Share on other sites More sharing options...
notfried Posted December 4, 2007 Report Share Posted December 4, 2007 good job,Ryan Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted December 4, 2007 Author Report Share Posted December 4, 2007 Thanks Russ! She came together real nice..and hopefully stays that way. Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted January 5, 2008 Author Report Share Posted January 5, 2008 Well I'm very happy so far. I finally got the steering wheel clocked to the correct position today, and I did a little something special for her I took this faded plastic http://img.villagephotos.com/p/2003-5/202062/IMGP05901.JPG and worked it over http://img.villagephotos.com/p/2003-5/202062/IMGP05981.JPG http://img.villagephotos.com/p/2003-5/202062/IMGP05971.JPG Quote Link to comment Share on other sites More sharing options...
notfried Posted January 5, 2008 Report Share Posted January 5, 2008 looks much better,man 8) Quote Link to comment Share on other sites More sharing options...
slowquest Posted January 5, 2008 Report Share Posted January 5, 2008 I REALLY like that color..... Quote Link to comment Share on other sites More sharing options...
W87NBS Posted January 23, 2008 Report Share Posted January 23, 2008 Another inspiration. Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted March 30, 2008 Author Report Share Posted March 30, 2008 (edited) Well, the project is now complete. The car has just been repainted the original color, R04 Mexican Red http://img.villagephotos.com/p/2003-5/202062/1988mitsstarion7362001.jpg http://img.villagephotos.com/p/2003-5/202062/1988mitsstarion7362004.jpg Edited March 30, 2008 by Ryan_V Quote Link to comment Share on other sites More sharing options...
DasGunner Posted March 31, 2008 Report Share Posted March 31, 2008 Well, the project is now complete. The car has just been repainted the original color, R04 Mexican Red Very nice ,looks good :eek1bluegreen: Quote Link to comment Share on other sites More sharing options...
emagdnim Posted March 31, 2008 Report Share Posted March 31, 2008 I can dig it. Quote Link to comment Share on other sites More sharing options...
Ryan_V Posted July 9, 2008 Author Report Share Posted July 9, 2008 I can dig it. Just found out a new member here- Gregster1234 is now the owner of this car! Quote Link to comment Share on other sites More sharing options...
mark0695 Posted July 22, 2008 Report Share Posted July 22, 2008 Just found out a new member here- Gregster1234 is now the owner of this car! why did you sell it after all that work if you dont mind me asking Quote Link to comment Share on other sites More sharing options...
Hoosierquest Posted July 22, 2008 Report Share Posted July 22, 2008 ill second that question Quote Link to comment Share on other sites More sharing options...
