CaliConquestAlex Posted September 23, 2006 Report Share Posted September 23, 2006 I finally worked all of the bugs out of my megasquirt and she started right up. I love the sound of her running. I missed it. Pics of the car will come soon. I need to tuck all of the wiring away. I would like to thank cashaudio for his help with getting my ignition working with the megasquirt. The setup he put in the megasquirt questions thread works perfect for me. I need to hook up the stock tach, but that is no biggie. Thanks CHAD for the magna intake. I don't know what else to say.... I'm extremely happy!!!! 6 Months of work was well worth it!!!! Link to comment Share on other sites More sharing options...
heefner Posted September 23, 2006 Report Share Posted September 23, 2006 Looks good. Do your self a favor and put an air filter on before you ruin your engine Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted September 23, 2006 Author Report Share Posted September 23, 2006 Yeah I have a new manifold to put on with a t3 flange and an external wastegate. I want to get a t70, I heard it is a great turbo for mpi. I am only running 55 lb injectors for now, but I will get a set of 72 lbs once the engine gets broken in. I can't belive how fast this thing revs.. It's amazing. I have a lightened flywheel which probably helps. I don't have an air filter for it yet, because the only setup I have is an hks 1g turbo mas canister with foam filter. The picture I have is about a month old with the magna distributor installed. I am using the stock distributor now, so I plan on selling that. I will be clearing out a whole lot of spare parts in the near future. Link to comment Share on other sites More sharing options...
Evil_Betty Posted September 23, 2006 Report Share Posted September 23, 2006 Very nice & glad to hear you got it running. I think I will take the Megasquirt route since so many people are having good luck with it. Can't wait to see more pics! -Jusitn Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted September 24, 2006 Author Report Share Posted September 24, 2006 Here are some pics of what she looks like as of today: http://img137.imageshack.us/img137/2108/dsc00001fk8.th.jpg http://img168.imageshack.us/img168/6335/dsc00003sb3.th.jpg http://img133.imageshack.us/img133/6513/dsc00004qn0.th.jpg http://img168.imageshack.us/img168/9105/dsc00005vf5.th.jpg http://img133.imageshack.us/img133/6372/dsc00006zu6.th.jpg I definitely need to clean up the wiring, and I still need to figure out how I'm going to put the megasquirt in the glovebox. Can you tell I like zip ties? They are good for everything. Link to comment Share on other sites More sharing options...
wasabii Posted September 25, 2006 Report Share Posted September 25, 2006 Congrats on getting the car running! Must feel good to see all your hard work finally paying off 8) . We're having a NorCal SQ meet on Oct 15th (check the StarQuest Meet Planner) and we would love to checkout your car there and hang out. Think you might be able to swing over? Later, Mitchell. Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted September 25, 2006 Author Report Share Posted September 25, 2006 Well I just killed my walbro 255 today so I think that'll set back my tuning on the car till i get another one. The car is still giving me issues and bucking a lot when I'm driving it. I am slowly learning the megatune settings by reading the megamanual over and over. Link to comment Share on other sites More sharing options...
wasabii Posted September 25, 2006 Report Share Posted September 25, 2006 Just take it easy man and your hard work will pay off, shoot, it's paying off already ! Feel free to stop by even if your car is not working and get to meet and hang out with other Starquesters in the area. Later, Mitchell. Link to comment Share on other sites More sharing options...
cashsaudio Posted September 25, 2006 Report Share Posted September 25, 2006 Well I just killed my walbro 255 today so I think that'll set back my tuning on the car till i get another one. The car is still giving me issues and bucking a lot when I'm driving it. I am slowly learning the megatune settings by reading the megamanual over and over. I just wanted to verified that you did this part, under the configurator did you change the max_spk_dur to 25.50? This is one of the main problem. after this is change then you change the settings on megatune with the dwell duration spark to 25.5 as goes for maximum spark duration in the ignition settings. DO NOT change the dwell settings to 25.50 until you have change the setting in the configurator or you may fry out your VB921 driver. Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted September 25, 2006 Author Report Share Posted September 25, 2006 I didn't change me dwell to 25.5 but I did change the spark duration to 25.5. Is that necessary? I didn't read that in the manual? Won't that heat the hell out of my coil if it is charging for so long? I killed my fuel pump because I had it running off of straight switched 12V and not through a relay or fuse. I was trying to get the thing started and when it did, I should've wired in a relay. I just picked up a realy kit so when I get the new pump I should be fine. Link to comment Share on other sites More sharing options...
MontyTSI Posted September 25, 2006 Report Share Posted September 25, 2006 just a question...how would a relay of saved your pump a relay is a straight feed to power thats turned on and off by a trigger voltage/ground. It is no different than keyed 12v power ( with the exception that you are isolating the circuit when using a relay). A fuse/ breaker on the other hand is a must... but the only time that would trip is if the pump was over drawing the circuit. So my question is, was your pump over drawing the circuit? What is the typical current draw for a wahlboro pump?... i think your pump had problems before you did anything. When you pull out your old pump put it directly on a battery and see if it turns on for a second or two Link to comment Share on other sites More sharing options...
cashsaudio Posted September 25, 2006 Report Share Posted September 25, 2006 just a question...how would a relay of saved your pump a relay is a straight feed to power thats turned on and off by a trigger voltage/ground. It is no different than keyed 12v power ( with the exception that you are isolating the circuit when using a relay). A fuse/ breaker on the other hand is a must... but the only time that would trip is if the pump was over drawing the circuit. So my question is, was your pump over drawing the circuit? What is the typical current draw for a wahlboro pump?... i think your pump had problems before you did anything. When you pull out your old pump put it directly on a battery and see if it turns on for a second or two I agree with monty Link to comment Share on other sites More sharing options...
cashsaudio Posted September 25, 2006 Report Share Posted September 25, 2006 I didn't change me dwell to 25.5 but I did change the spark duration to 25.5. Is that necessary? I didn't read that in the manual? Won't that heat the hell out of my coil if it is charging for so long? I killed my fuel pump because I had it running off of straight switched 12V and not through a relay or fuse. I was trying to get the thing started and when it did, I should've wired in a relay. I just picked up a realy kit so when I get the new pump I should be fine. Then you didn't read very well from this webpage http://www.megamanual.com/ms2/msd6a.htm Under the dwell settings:Parameter Value Maximum Dwell Duration 25.5 To set the dwell to 25.5, you'll have to change one of the megasquirt-II.ini file. Edit the following line: max_coil_dur = scalar, U08, 4, "ms", 0.10000, 0.00000, 1.00, 8.00, 1 ; * ( 1 byte) to max_coil_dur = scalar, U08, 4, "ms", 0.10000, 0.00000, 1.00, 25.50, 1 ; * ( 1 byte) The only reason you would burn out your coil if you have the coil hooked up directly to MS. Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted September 26, 2006 Author Report Share Posted September 26, 2006 oh my bad...I missed that part. LOL I had my pump wired directly to 12V power and it bruned up the pump because the amps and volts were unregulated. Link to comment Share on other sites More sharing options...
artinist Posted September 26, 2006 Report Share Posted September 26, 2006 oh my bad...I missed that part. LOL I had my pump wired directly to 12V power and it bruned up the pump because the amps and volts were unregulated. the amps and volts are the same everywhere you pick up power from. Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted September 26, 2006 Author Report Share Posted September 26, 2006 i had the switched 12v coming from the ecu power source. maybe the pump just went bad on it's own then, makes me feel a little better. Link to comment Share on other sites More sharing options...
button Posted September 26, 2006 Report Share Posted September 26, 2006 MAYBE, you didnt change the in tank filter? or conical filter?that would over work a walbro. and cause a lean condition under load causing bucking.. wiring it straight to 12v is FINE and actually recomended. 12v is 12v, IT decides what AMPS it needs by creating a load. more load more amps. Just a Maybe. Otherwise, lookin good man! Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted September 26, 2006 Author Report Share Posted September 26, 2006 I read in the megamanual that wiring to switched 12V isn't good for running all the time because in case of an accident if there is a fuel line cut the pump will not shut off on it's own. It's better to have the megasquirt control the pump because the megasquirt kills the pump if there is no rpm signal for 2 seconds. Link to comment Share on other sites More sharing options...
mrdodge01 Posted September 26, 2006 Report Share Posted September 26, 2006 Yeah, for THAT reason it is better to run from the megasquirt, but that has nothing to do with the life of your pump... I'd say check those filters, grab a new walbro, and enjoy that ride! Link to comment Share on other sites More sharing options...
Shelby Posted September 26, 2006 Report Share Posted September 26, 2006 what they intend for you to do is use that signal wire to triger a relay not actualy power the pump , it may be more likely you burnt out that signal wire in the ecu more then your fuel pump quiteing Link to comment Share on other sites More sharing options...
MontyTSI Posted September 27, 2006 Report Share Posted September 27, 2006 what they intend for you to do is use that signal wire to triger a relay not actualy power the pump , it may be more likely you burnt out that signal wire in the ecu more then your fuel pump quiteing that was exactly my point.. i put it at the bottom (probably should of put it at the top) hook your FP directly to a battery for just a second or two to see if it turns on... not too long, its never good to dry run one. Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted May 2, 2007 Author Report Share Posted May 2, 2007 Update... I just put the t70 turbo and I am in the process of having a full 2.5 inch mandrel bent exahust made custom for the turbo setup. It should be ready by this weekend. All I need is the Innovative LC-1 wideband setup and I'm ready to go! NEW PICS will be added this weekend! I had no problems with the ebay t70 turbo as of yet, but we'll see how it is in a couple thousand miles. I am down for the next norcal meet! Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted May 10, 2007 Author Report Share Posted May 10, 2007 New Pics with the t-70 turbo installed and running: http://img249.imageshack.us/img249/5217/img1152cx1.jpg http://img526.imageshack.us/img526/6017/img1155if5.jpg http://img526.imageshack.us/img526/7576/img1153fl3.jpg It is still a WIP, but it runs pretty good and the LC-1 wideband kit is on the way. Link to comment Share on other sites More sharing options...
jawatech Posted May 16, 2007 Report Share Posted May 16, 2007 NICE! Thats about what im going for except i have a T67. Link to comment Share on other sites More sharing options...
tigertron Posted May 16, 2007 Report Share Posted May 16, 2007 NICE! Thats about what im going for except i have a T67. thats a good turbo Link to comment Share on other sites More sharing options...
