JustPaus_88TSi Posted November 29, 2004 Report Share Posted November 29, 2004 http://2.6liter.com/userfiles/StarPauser/P1010037.JPG Link to comment Share on other sites More sharing options...
Professor Quest Posted November 29, 2004 Author Report Share Posted November 29, 2004 Two valves were stuck with rust. Note "DRIFT-PIN". Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 29, 2004 Report Share Posted November 29, 2004 http://2.6liter.com/userfiles/StarPauser/P1010038.JPG Link to comment Share on other sites More sharing options...
Professor Quest Posted November 29, 2004 Author Report Share Posted November 29, 2004 A little carb cleaner on the stems........a few LIGHT TAPS with the mallet........BINGO! Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 29, 2004 Report Share Posted November 29, 2004 http://2.6liter.com/userfiles/StarPauser/P1010039.JPG Link to comment Share on other sites More sharing options...
Professor Quest Posted November 29, 2004 Author Report Share Posted November 29, 2004 Throw all the parts in a coffee can or parts cleaner and let them soak. I parked the head in the "Berryman Chem Dip" and flip it once in a while. One spark plug already came out! ;D A few hours later........number two was in the trash. That "Berryman" is some BAD STUFF. Link to comment Share on other sites More sharing options...
Tim_C. Posted November 29, 2004 Report Share Posted November 29, 2004 Slide one of the rockers to the side........this is an oil port that feeds the rocker.......that feeds the LIFTER. As you can see.....then fill with CRUDE. Okay, this post refers to the picture above the original post from this quote. That is not the hole that feeds oil to the lifter. We have to be careful in describing the lifter feed hole, because some early shafts don't have it. We lucked out with that pic though. In the pick, you can see on the bottom part of the shaft, a cut-out/slot cut sideways in the shaft. That slot contains a small hole, not visible in the picture. That hole is the lifter oil feed hole. The early/mechanical rocker only shafts, do not have that cross-cut/sideways slot in them, and can not feed oil to a hydraulic lifter. The hole shown in the picture is on all shafts, early/late, doesn't matter, and it only lubricates the rocker turning on the shaft, not the lifter. If you investigate, you will see the other hole lines up perfectly with the hole in the inner diameter of the rocker, and it shoots pressurized oil to the lifter. Also, as the professor knows, and probably mentioned, exhaust rockers have an extra oiling hole to oil the cam lobe, whereas intake rockers do not have that hole. So, if you elim the JV's like we all do, you can use all exhaust rockers for a little extra oil to the intake cam lobes, as well as the exhaust cam lobes. Very small hole in the rocker that shoots oil directly on the cam lobe. Easy to miss if you're not looking for it, but very obvious if you look. Link to comment Share on other sites More sharing options...
Dcrasta Posted November 29, 2004 Report Share Posted November 29, 2004 Hey tim , questions about your last post. 1: Do mechanical only heads( aka caravan) have this lifter oiler (on the exhaust side?) 2: Can I use a exhaust rockers on my intake side to get this oil feed on all my cam lobes? sounds like free reliability to me.. Thanks. Link to comment Share on other sites More sharing options...
Professor Quest Posted November 30, 2004 Author Report Share Posted November 30, 2004 Slide one of the rockers to the side.......this is an oil port that feeds the rocker.......the slot below feeds the LIFTER. As you can see.....they fill with CRUDE. Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 30, 2004 Report Share Posted November 30, 2004 http://2.6liter.com/userfiles/StarPauser/P10100080-3.JPG Link to comment Share on other sites More sharing options...
Professor Quest Posted November 30, 2004 Author Report Share Posted November 30, 2004 My turn to do the "POTS & PANS" Â ;D The air tools can be substituted with a drill. You only need a couple wire wheels to do this. Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 30, 2004 Report Share Posted November 30, 2004 http://2.6liter.com/userfiles/StarPauser/P1010007-3.JPG Link to comment Share on other sites More sharing options...
Professor Quest Posted November 30, 2004 Author Report Share Posted November 30, 2004 Larger chunks of carbon can be removed with a center punch. Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 30, 2004 Report Share Posted November 30, 2004 http://2.6liter.com/userfiles/StarPauser/P10100010-3.JPG Link to comment Share on other sites More sharing options...
Professor Quest Posted November 30, 2004 Author Report Share Posted November 30, 2004 Typical cracked head. 88 heads are suppose to be made from better Ali. according to the factory "88 up grades" list I have from Mitsu. So much for the "up-grade" : Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 30, 2004 Report Share Posted November 30, 2004 http://2.6liter.com/userfiles/StarPauser/P10100020-3.JPGSo Prof.. What's with the roundish metal thing? If the spark plug was installed, it'd point right at what i'm talking about.. It has a little hole in it's side.. What the hell is that? Link to comment Share on other sites More sharing options...
Professor Quest Posted November 30, 2004 Author Report Share Posted November 30, 2004 Those RIDICULOS jet valve CAPS! > Number 2 and 3 are both cracked. Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 30, 2004 Report Share Posted November 30, 2004 Oh, I was thinking that, but I envisioned an open cylindrical shroud.. So the jet valve shroud has this cap on it? That's wak ;D http://2.6liter.com/userfiles/StarPauser/P10100050-3.JPG Link to comment Share on other sites More sharing options...
Professor Quest Posted November 30, 2004 Author Report Share Posted November 30, 2004 I think most guys just see the crack at the top. But the guy who fixes these told me they run REAL DEEP. He ain't kidding! As you can see in the following pics......the crack runs down BOTH PORTS. Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â I guess they wanted to DIRECT the JET. Â Â Â Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 30, 2004 Report Share Posted November 30, 2004 http://2.6liter.com/userfiles/StarPauser/P1010009-3.JPGRemember kids, crack kills ... Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 30, 2004 Report Share Posted November 30, 2004 http://2.6liter.com/userfiles/StarPauser/extracting%20studs.JPG Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 30, 2004 Report Share Posted November 30, 2004 http://2.6liter.com/userfiles/StarPauser/Transfer%20punch.JPG Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 30, 2004 Report Share Posted November 30, 2004 http://2.6liter.com/userfiles/StarPauser/P1010012-3.JPG Link to comment Share on other sites More sharing options...
Professor Quest Posted November 30, 2004 Author Report Share Posted November 30, 2004 Top pic........some necessary tools. 2nd pic close up of a "TRANSFER PUNCH". 3rd pic I "leved-out" the playing field. Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 30, 2004 Report Share Posted November 30, 2004 http://2.6liter.com/userfiles/StarPauser/P1010011-3.JPG Link to comment Share on other sites More sharing options...
