SDS comments on my damage and fuel line size
Hi,
The damage is consistent with pre-ignition or detonation. It likely
melted under boost. can't melt on decel as the engine makes no power and
the fuel cut under vacuum cuts off all fuel- no fuel-no combustion-no
heat, The air coming in actually cools everything down super quick.
Caused by too much boost, too lean, not high enough fuel octane, too
much timing, plugs to hot on the heat range. If the fuel pressure holds
under boost at high rpm and boost and duty cycle is less than 90%, the
mechanicals are ok. 5/16 fuel line is fine to over 600hp. If it is
programmed too lean, it will melt even JE pistons.
Cheers,
Ross
Mike K wrote:
> Hi Ross  I just had my car on the dyno. On the last pass I shattered a
> JE forged piston:      This happened when Iet off on the last pass on
> decel, it didn't happen under load which confuses me.  Is there any
> way this was caused by having the map values shut off on high vacuum
> readings? I have 0's on my MAP values above 24". This is a turbo
> charged Starion 2.6L BTW. I run stock fuel lines and a high pressure
> pump. Do you think a larger fuel line will be needed? Here is my
> last dyno run:    Thanks Mike K
A little brief wasn't he?  I'd want some more out of the guy myself I mean he didn't really even address all of your questions.  Just told you that it was impossible for that to happen off boost.  SDS provides good tech support right?  I've heard they're great.  Anyway, he has a firm grasp of the obvious if you ask me and pretty much just covered all the common possibilities.  We'll get it figured out and know exactly what happened eventually Mike.  I like what he said about the fuel lines though
I've got 2 bad pistons.
#4 is the cracked one
#3 is mushroomed over in the same place where #4 cracked.
Block is beyond boring due to the cracked piston in #4. Several large gouges that would be low spots if it were honed. It needs to be rebored.
ok, i just read your other post.  #4 it was.
have you thought about a Dual Feed fuel rail?  in most cars with large injectors the first three injectors will starve the #4 injector of fuel, causing it to run lean and detonate independently of what's going in in #1-3.  this is a super common problem on turbo'd miatas and it always fixes the lean #4 problem.
basically you add another fuel inlet on the end of the fuel rail that is the return side, then put a return in the center of the rail, then tee your fuel feed to both ends.  you get much more even fuel volume that way with the big injectors that you run.
That's a really great idea.
But the fuel regulator is built into the rail at the end. Ulitmately that would mean I would need to relocate the regulator.
Wouldn't a larger fuel line supply more volume to get around a starvation problem?
How is it set up, got any pics from one of your Miata amigos?
Mike i  would n't question the experts but  heres a little  lesson learn'd running chyr  big block 440's with two carder AVS's the stock carb's  wouldn't  hold more then 12lb of fuel  pressure befor   pushing the  neddle and seat off causeing flooding, so with  the two carbs the  problem was solve'd by running  3/8 fuel line and  not the 5/16 they came with , this alow'd us to use less fuel pressure, and still  maintain engought fuel at 10 psi to  keep both carbs full
point being theres two ways of  moveing  fuel , volume and pressure , a larger  line will always alow the same amount of fuel to be deliver'd at much  less  pressure then a smaller   one will
almost all inj's have an ideal fuel pressure working range where they can  maintain a  proper  atomization of the fuel , too much or too little pressure  up sets this  pattern , even if  as he says the 5/16 could  flow enought to  maintain  the proper  fuel volume, i  can't see what haveing a larger fuel line  could hurt,  it would at the very least  help keep the  fuel pressure  from haveing to be  rasie'd  too  much , alowing the  pulse width to do the  mixture corecting as it should with out a sevier   raise  in fuel pressures  , but i guess this will al be work'd out by next yr  or hopefuly it will ,  trial and error  gets  real expensive huh
:) i ment  that i wasn't  trying to  question the expert's ,not that i was one in any sence of the  word , i'm  just an old "wrench" here  to learn  like a lot of others
a lot of  very  intersting stuff has come up  in these  last few threads
Personally, as been said before, I think it was heat (no detonation)... I think you had to much timing into it for a 13:1 AFR... very hot.
My buddies FC rx7 did the same thing at 13.5:1, heard no detonation... just heard the rotor go (apex seal broke)...
Joel
Hey Mike, Sorry to hear about your engine. I am a little confused. Which end of the fuel rail are you feeding the fuel into (cyl 1 or 4)?  What boost level and octane fuel were you running when the piston came apart? You have me wonder about how close to the edge I am???
Ross might be right about the detonation thing. Remember the Magna flows much more air than a stock intake at 20 psi, so detonation will happen sooner at that boost level. I found that running anymore boost than 17lbs on Sunoco 94 octane gas gave me detonation with the Magna. If I tried richening up the fuelcurve or backing off the timing it would just take power away from my car, so I would think that 17 psi is optimum boost while running 94 octane fuel. I am presently mixing 100 octane Aviation fuel with pump gas inorder to run 20psi.
Starting from the trunk my fuel system consists of a Bosch racing pump good for 500 HP, stock fuel lines to engine bay, a BG high flow fuel filter with a 3/8" ID fuel hose feeding the rear of fuel rail. I have the fuel rail inlet tapped to 1/4NPT and I am using a 1/4 NPT Stainless Steel 90 degree street elbow threaded into it. I am using 72 lb siemen injectors. I am also using the stock Magna fuel regulator with a uniasia boost referenced fuel regulator piggybacked in the return fuel line to bring the fuel pressure up to about 43 lbs at idle and 60 lbs while under boost. The Magna regulator won`t maintain a high enough fuel pressure by itself.
Darryl
I run the fuel inlet starting on #4.
I was running 93 ethanol blend pump gas. The piston went at 18psi. I was having a little problem at 15psi but I got that under control. At 18psi it was out of control. I dialed in a lot of fuel and, was at 255 on my map readings at 18psi!!
I couldn't get anything more than 15psi to run decent on pump gas.
Fuel pressure is 34 baseline, 1:1 with my fuel pressure reading ~50 at 15 psi with 75lb injectors.
I used the stock FPR as it always held the pressure consistent. SDS told me as long as the fuel pressure is holding and your not maxing out your duty cycle your alright.
Your doing it right Darryl. Kept that high octane fuel in it!
I would love to see your car on the dyno Darryl.
yeah, it seems you fuel pressure was pretty low at that high of a boost level.  should be more like 40psi baseline and 1:1 rate of rise per psi for those big injectors and the 20G.  darryl did make a very good point there, i hadn't paid much attention to your pressure numbers.  i ran those numbers by a local dyno tuner and he said your working pressures look a bit too low for that size injector/turbo combo.
just as a  referance the last dsm 91 lazer i ran a fuel system check on the stock reg they use was 46lb at idle and  56lb at 10lb of  boost , the dsm reg  looks  like it may fit the  aussie fuel rail with a  mod to the  bolt  down bracket , not sure if that would help or not , but the  fuel  reg will   give  more then  56 lb, not  sure ho much more tho
Maybe your volume is such that you need 8 smaller injectors with a higher baseline for optimal atomization? Or, run 45-50+ PSI baseline on the 4 bigger injectors to see what that does for duty cycle to volume ratio?
I really like the bigger fuel line idea. But, a higher baseline pressure will atomize better, so when you increase the fuel, it will still spray well enough to give HP, not lose it like what is happening to Daryl? I think Daryl's point of detonation at 17 PSI could be due to a loss of atomization characteristics.
My engine just loves high fuel pressure. Even before, it really ran better, and even boosted 1PSI or so more when I turned up the baseline pressure to 50. Of course, now my baseline needs to be 70! Needless to say, it is parked until I get the fuel somehow. That's why I'm watching all these threads, and maybe being a little pesimistic at times. I'm about ready to go one route or another, and need to decide. I'm leaning toward an added injector since I can actually get there @10PSI boost with what I have.
Just some thoughts.
Tim C.
http://www.sacskyranch.com/deton.htm
Good pics and info o what detonation looks like....  In this case jet fuel got into the gas lowering the octane and damaging engines.
Regardless of the cause the damage pattern is the same.
Kevin C
