84germ Posted October 31, 2023 Report Share Posted October 31, 2023 The car starts and runs fine in idle and will rev up with no load but once I put it into gear it bogs out and dies. Any ideas? Quote Link to comment Share on other sites More sharing options...
scott87star Posted October 31, 2023 Report Share Posted October 31, 2023 Lack of fuel flow, check/change the filters, check the pump pressure. Quote Link to comment Share on other sites More sharing options...
TSITy Posted October 31, 2023 Report Share Posted October 31, 2023 Check injector clips & secondary injector (green one) Quote Link to comment Share on other sites More sharing options...
kev Posted October 31, 2023 Report Share Posted October 31, 2023 It's an 84...sequential injectors...no green one. But, it could still be a clogged injector. Any leaks in the intake system (between turbo and injectors). On 84s, it is common that the o-rings on the turbo to OVCP leak bad. That will cause unmetered air to enter the system and drastically lean out the car. It's air/fuel related. Start simple with cleaning your injectors and making sure they are spraying and check to make sure you aren't pulling in any air after the MAS. Once you know those items are good, move forward with harder items. Quote Link to comment Share on other sites More sharing options...
