84 quest dies under load
84germ
It's an 84...sequential injectors...no green one.   But, it could still be a clogged injector.
Any leaks in the intake system (between turbo and injectors).   On 84s, it is common that the o-rings on the turbo to OVCP leak bad.  That will cause unmetered air to enter the system and drastically lean out the car.
It's air/fuel related.   Start simple with cleaning your injectors and making sure they are spraying and check to make sure you aren't pulling in any air after the MAS.   Once you know those items are good, move forward with harder items.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
