tux Posted August 19, 2023 Report Share Posted August 19, 2023 (edited) Does anyone know how to get the circuit board out of the plastic casing? I was able to get the cover off and the entire thing was filled with some clear sticky substance. But I'm in need of removing the board to fix a blown capacitor and some visibly broken traces. Edited August 19, 2023 by tux Link to comment Share on other sites More sharing options...
psu_Crash Posted August 27, 2023 Report Share Posted August 27, 2023 I have never seen one apart so I'm not much help. Have a pic? Sounds like it is epoxied in there. Link to comment Share on other sites More sharing options...
scott87star Posted August 27, 2023 Report Share Posted August 27, 2023 I’ve taken many of them apart but I’ve never tried to save the internals, both boards are molded in by tabs on the side structure. Try using a dremel with a cut off wheel to score the top and bottom covers. The sticky goo is a pain to deal with, it’s there to seal out the elements and help transfer heat. I don’t know of a solvent off the top of my head but start with isopropyl alcohol, move to acetone if the IPA isn’t effective. Once repairs are completed use conformal coating to seal things up. Link to comment Share on other sites More sharing options...
scott87star Posted August 27, 2023 Report Share Posted August 27, 2023 PM me an address, I checked my parts pile and came up with 5, including two that have clearly been opened up before. You can use them to experiment and/or one of them is likely good. Link to comment Share on other sites More sharing options...
tux Posted August 29, 2023 Author Report Share Posted August 29, 2023 I wanted to avoid dremeling them out. I cant see how they got it in there to begin with, unless the plastic was formed around the PCB, which seems unlikely. The back came off pretty easy using a hot air station. Hot air station helped separating the two boards. but I'm just perplexed as to how to get the PCB out of there! Thanks for the offer Scott. I'll give you a ping. Maybe I can cobble something together that works. I'm sure some of these components I may not be able to find on mouser. Link to comment Share on other sites More sharing options...
