03CL55AMG Posted November 10, 2014 Report Share Posted November 10, 2014 So my main brak lights are not working...only the smaller one on the hatch, I have checked the bulbs and the fuses..both are good. I even changed the brake light switch, stll no main brake lights, not sur if this is related but when cruising the other night with the cruise control on..the cruise would kick off for know reason, I would just hit resume and it would be good to go, but it did that 3 times. Anyway not sure what else to check on the brake light issue...any ideas would be appreciated, thanks. Link to comment Share on other sites More sharing options...
nightwalkerancestery Posted November 10, 2014 Report Share Posted November 10, 2014 Have you taken off the gauge hood recently? - Charles Link to comment Share on other sites More sharing options...
Alan Posted November 10, 2014 Report Share Posted November 10, 2014 Check corrosion in bulb sockets. And ground. Link to comment Share on other sites More sharing options...
03CL55AMG Posted November 10, 2014 Author Report Share Posted November 10, 2014 No..I hve not had the gauge hood off for a long time...I did not see any corrosion when I check today. Link to comment Share on other sites More sharing options...
scott87star Posted November 10, 2014 Report Share Posted November 10, 2014 Align the hatch and clean the contacts on the hatch struts. Link to comment Share on other sites More sharing options...
Starfighterpilot Posted November 10, 2014 Report Share Posted November 10, 2014 Check out FSM Page 8 -188. It may be that the hazard switch may be going to Starquest heaven. Or that the #2 fuse retainer "clips" in the fuse block under the drivers side dash are loose or corroded. See FSM 8-103. #2 fuse powers the stop light and cruise control circuits. I don't think that the problem has anything to do with grounds. Cuz if the grounds were bad, the tail lites wouldn't lite up and he didn't say that they were not working. In the OP - he was specific in saying the brake lites were the problem. But WTH - I may be wrong. For What It's Worth. KEN Link to comment Share on other sites More sharing options...
03CL55AMG Posted November 10, 2014 Author Report Share Posted November 10, 2014 I will try that star...I did notice that the small hatch brake light will not work unless the hatch is closed, so that made me think along those same lines,thanks. Link to comment Share on other sites More sharing options...
Starfighterpilot Posted November 10, 2014 Report Share Posted November 10, 2014 I did notice that the small hatch brake light will not work unless the hatch is closed, That's what's supposed to happen cuz it's powered and grounded through the left hand rear hatch strut electrical copper connecters/contacts. For What It's Worth. KEN Link to comment Share on other sites More sharing options...
nightwalkerancestery Posted November 12, 2014 Report Share Posted November 12, 2014 Do they work if you turn on the hazard switch? - Charles Link to comment Share on other sites More sharing options...
03CL55AMG Posted November 15, 2014 Author Report Share Posted November 15, 2014 Yes the rear lights do work when the hazzards are on...hmmm. I am dbl checking the contacts Link to comment Share on other sites More sharing options...
scott87star Posted November 15, 2014 Report Share Posted November 15, 2014 Power for the brake lights flows through the hazard switch when its in the off position. Power for the hazards flows through when the hazard switch is in the on position. Have you cleaned the contacts in the hazard switch? Link to comment Share on other sites More sharing options...
03CL55AMG Posted November 16, 2014 Author Report Share Posted November 16, 2014 Well, I guess thst will be the next step...I did not know that the power ran through the hazard switch...so I will clean them next. I did pull the hood off and pull apart all the switches but it has been awhile since I did that..thanks Link to comment Share on other sites More sharing options...
nightwalkerancestery Posted November 16, 2014 Report Share Posted November 16, 2014 That was going to be my suggestion as well. I had my gauge hood off in the past and put it back together and everything worked like usual...for a while. Then one day my brake lights suddenly stopped working. Wth?! After going through some posts on here, I found that if the hazards work but the brake lights don't, it's usually just the connector under the hood. It turned out that I didn't fully seat the connector and over time it wiggled itself apart until the contacts weren't touching for the brakes. Though it'd still be good to disassemble and clean the contacts for the hazards, it's possible to get away with just reseating the connector. Since your hazards do work, I can say it's most likely going to just be the connector for the hazard switch assembly or the actual switch itself. Let us know what you find out. - Charles Link to comment Share on other sites More sharing options...
03CL55AMG Posted November 17, 2014 Author Report Share Posted November 17, 2014 I will post what I find...it will most likely be next weekend before I get to it...thanks Link to comment Share on other sites More sharing options...
03CL55AMG Posted November 23, 2014 Author Report Share Posted November 23, 2014 Ok, well I dug around and found a new hazard light harness and changes it out and the brake light now work. Thanks for the advise and you guys that said it was the switch thst the hazzards were hooked tonerre correct. Back on the the road again. Link to comment Share on other sites More sharing options...
nightwalkerancestery Posted November 24, 2014 Report Share Posted November 24, 2014 Good to see you got it sorted out. Keep it boostin'! - Charles Link to comment Share on other sites More sharing options...
