Alan
Alan last won the day on August 24 2015
Alan had the most liked content!
About Alan
- Birthday 07/24/1955
helicopters
harley's
quest's -
Huntsville, Al
35811
1989
Auto
Polar White
Dark Red
Alan's Achievements
The passing control relay has nothing to do with the transmission. Check that the wiring harness is hooked up on top of the bell housing next to the rear of the block as well. Remember that the OD operation is controlled by temp. If engine is cold it should not go into OD. The switch on the shifter only allows you to turn off and to engage if the temp requirement is meet. Check in forum and FAQ,s.
I'll take send me PayPal again. On the road now my be tomorrow before I hit you back. Alan
Check corrosion in bulb sockets. And ground.
Sorry I didn't back with you guys yesterday, other projects at the house. I sent a primary first that was leaking, cost about 4 $ to ship and 40 something for the service. They shipped it back, quick turnaround. Not sure what all they do to them, but it works and installed in the car. Then I sent my original pri/sec for the same service. They called and explained that the internal problem they could not repair/fabricate. Returned to me and refunded payment. Then I sent 2 secondary that Dave gave me. Same thing with them. So now I am out a secondary. If you would Mark, send me payment info for the ones you have. Hit me on this site or owenbyj@outlook.com I'm going to check one more source. Thanks guys!
The first primary I sent went well. They have you send to GB Manufacturing in Calf. The others I sent could not be saved. They called to explain. So no complaints.
My injectors leak. Did the TBI kit several times and sent thru Rock Auto for Reman/Return, no luck. David(87quest-TSI) had several to donate, no luck there either. Any recommendations? Has anyone used the ones from fuelinjectorclinic? 89, stock other that no Balance shafts, jet valves, and egr/exhaust emissions. Thanks!
On my 89 auto it was mounted to the transmission stud on top of the mount. In the last pic that would be under the nut just below speedo cable as pictured.
http://www.foxnews.com/leisure/2014/03/28/5-nearly-extinct-cool-cars-from-70s-and-80s/?intcmp=obnetwork Starquests featured here. Alan
Brought home My new project last night (Daughter!)
Alan replied to nomad's topic in Just plain ol' B.S.
Great! They do make time fly. I'll get Cathy to do a baby quilt. Best to all of you. Stay in touch and enjoy! -
Starquestgarage.com, 1988 FSM start on page 21-82. Drawing breakdown.
L4N71B Rebuild Walkthrough (well...Greatest Hits)
Alan replied to natallica's topic in Automatic Transmissions
Great job! I knew you could do it. Looks great also, I now have a parts washer for a better cleaning job. Wish I had thought to build a box cradle like you did, I just flipped it over. Congrats!! -
The shaft is very hard to turn once every thing is bolted up. The FSM has a drawing that shows location of the washer bearings. I'll try to remember to look when I get home from work. Edit: IN the 1988 manual look at page 21-83 and item #3 on page 21-91 for that bearing washer. Different page numbers in the 1989 manual. Good luck!
