Turbospecv Posted September 9, 2014 Report Share Posted September 9, 2014 hey guys need some help. I removed the black catch can connected to my intake that goes to the valve cover and to the oil pan and I put a little filter on the valve cover. ok so my question is do I cap the other holes or leave them open. last thing is after I did this my check engine light went off and it flashed 7 times which is coolant sensor now was this just coincidence or are these two connected and now just not receiving enough air. Quote Link to comment Share on other sites More sharing options...
scott87star Posted September 9, 2014 Report Share Posted September 9, 2014 Clean out the catch can and put it back on, it does a lot to keep things working properly as long as its working properly. Quote Link to comment Share on other sites More sharing options...
Fuze Posted September 9, 2014 Report Share Posted September 9, 2014 I would just replace the stock seperator can with a cheap aftermarket one rather then running a filter and plugging things. Your engine will get totally filthy with that little filter and there's nothing pulling the gasses out of the crankcase. Quote Link to comment Share on other sites More sharing options...
Turbospecv Posted September 10, 2014 Author Report Share Posted September 10, 2014 Oh ok make sense I will definitely put it back on Quote Link to comment Share on other sites More sharing options...
Turbospecv Posted September 10, 2014 Author Report Share Posted September 10, 2014 So which would be the best way to clean the catch can ? Quote Link to comment Share on other sites More sharing options...
psu_Crash Posted September 10, 2014 Report Share Posted September 10, 2014 Soak it with a solvent such as mineral spirits or kerosene if you are VERY careful. Shake it around once it's mostly filled up for a while. Dump it out and repeat. Once the liquid runs mostly clean you are done with that step. I used a little dawn with hot water for the final rinse. Then rinse with hot water until it runs clear. Quote Link to comment Share on other sites More sharing options...
Shelby Posted September 14, 2014 Report Share Posted September 14, 2014 you can simply blow tru all the ports with your mouth to se if it is pluged Quote Link to comment Share on other sites More sharing options...
