IBSK8N Posted August 23, 2013 Report Share Posted August 23, 2013 Wipers work, but the intermittent does not. They get stuck or start to wipe, then quit, then try to wipr, get stuck, then wipe, get stuck.... Is this a relay issue or wiper motor? Quote Link to comment Share on other sites More sharing options...
scott87star Posted August 23, 2013 Report Share Posted August 23, 2013 I wish I knew, I've run through all the FSM testing and both the motor and relay test fine but BOTH my windshield and rear wipers do the exact same thing on my Flatty. The fatty has always worked fine. I have seen Shelby explain in threads that the motor must run backwards to park the wipers but there is a test in the FSM where you remove power during a sweep and they both complete the sweep and park. I keep thinking its the relay but they pass the tests too. I'm open to suggestions. Quote Link to comment Share on other sites More sharing options...
Walker Posted August 23, 2013 Report Share Posted August 23, 2013 in my case...it was rust/corrosion ....if you remove the wiper shrouds you will notice it Quote Link to comment Share on other sites More sharing options...
vbrad511 Posted August 23, 2013 Report Share Posted August 23, 2013 Our wipers have an "auto-park" feature. What usually happens is the 20 year old grease inside gets on the contacts inside the motor and stops the auto connections from completing. You'll need to take the motor out, and pull the flat plate off. Pay attention to how it comes apart. Clean the nasty grease out of the insides and off the contacts, put a bit of fresh grease back inside and give it another try. Now would also be a good time to pull the wiper transmission assembly out and clean the posts and the joints. Quote Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted August 24, 2013 Report Share Posted August 24, 2013 Our wipers have an "auto-park" feature. What usually happens is the 20 year old grease inside gets on the contacts inside the motor and stops the auto connections from completing. You'll need to take the motor out, and pull the flat plate off. Pay attention to how it comes apart. Clean the nasty grease out of the insides and off the contacts, put a bit of fresh grease back inside and give it another try. Now would also be a good time to pull the wiper transmission assembly out and clean the posts and the joints. I second this! Scott, try giggling the stalk to see if that affects it. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted August 25, 2013 Report Share Posted August 25, 2013 6 quests and none of the int wipers ever worked properly.only my 87 starion worked properly when it felt like it. Quote Link to comment Share on other sites More sharing options...
D3UC3S Posted August 28, 2013 Report Share Posted August 28, 2013 Haha. I just unplugged mine and gave the windshield a heavy coat of rain-x Quote Link to comment Share on other sites More sharing options...
Crazy larry Posted September 17, 2013 Report Share Posted September 17, 2013 Some times the previous owner turned the wipers on say in the winter when the wipers were frozen to the glass... or the wipers at one time were forced to move. inside the wiper motor the gear is plastic and it Breaks... replace the motor... problem solved.. Yes the Grease inside the motor is hard to clean up... Quote Link to comment Share on other sites More sharing options...
jimalan1989 Posted October 20, 2013 Report Share Posted October 20, 2013 my intermitten wipers didn't work, along with the power door locks not working right, and my window would constantly go up and down not matter how long the car sat with the key out. looked in the FSM to see all those circuts shared the same module. the ETAC module under the seat. I replace with a spare I took from my parts car and it fixed my problems 1 Quote Link to comment Share on other sites More sharing options...
Starfighterpilot Posted October 24, 2013 Report Share Posted October 24, 2013 Our wipers have an "auto-park" feature. What usually happens is the 20 year old grease inside gets on the contacts inside the motor and stops the auto connections from completing. You'll need to take the motor out, and pull the flat plate off. Pay attention to how it comes apart. Clean the nasty grease out of the insides and off the contacts, put a bit of fresh grease back inside and give it another try. Now would also be a good time to pull the wiper transmission assembly out and clean the posts and the joints. I third this. For What It's Worth. KEN Quote Link to comment Share on other sites More sharing options...
mistapickles Posted October 24, 2013 Report Share Posted October 24, 2013 my intermitten wipers didn't work, along with the power door locks not working right, and my window would constantly go up and down not matter how long the car sat with the key out. looked in the FSM to see all those circuts shared the same module. the ETAC module under the seat. I replace with a spare I took from my parts car and it fixed my problemsThis guy has it dead on... The intermittent wipers not working is the clue, if it was anything that anybody else was talking about they just wouldn't work but since the regular modes work its the ETAC... Fun part is going to be finding the right ETAC, there are multiple part numbers for multiple years and they don't cross over very well... Quote Link to comment Share on other sites More sharing options...
importwarrior Posted October 25, 2013 Report Share Posted October 25, 2013 i would start by removing the motor and cleaning the old crusty grease and contacts first. then see how it works. Quote Link to comment Share on other sites More sharing options...
vbrad511 Posted October 27, 2013 Report Share Posted October 27, 2013 And one of the bolts that holds the motor to the firewall SHOULD have a metal grounding strap on it. My 88 didn't have it when I got the car so the auto park feature didn't work. I added an additional ground wire and it fixed it, but once I realized I was missing that strap and replaced it I removed that other ground. And when I say "strap" I mean it's just a little metal tab that kinda folds around the rubber on one of the bolts. It touches the head of the bolt on one side and the firewall on the other. If things are dirty under your hood it may be tough to see. Quote Link to comment Share on other sites More sharing options...
marso Posted November 2, 2013 Report Share Posted November 2, 2013 Another thing to check is the Intermittent Wiper button on the lower left side of the dash. It does an instant intermittent cancel when pushed. Mine was dirty and caused the same issue as you. I cleaned it with electronics spray while pushing it in a bunch of times. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted November 2, 2013 Report Share Posted November 2, 2013 any update on this?please post a fix. Quote Link to comment Share on other sites More sharing options...
