2fast2six Posted July 1, 2013 Report Share Posted July 1, 2013 so while installing my rear struts and springs the cv axles where its splined had pulled out from the rear diff. do i just push them back in and make sure that they are pushed in all the way when i bolt everything back together? i see that theirs a c clip on the end of the splines of the cv axle. just want to make sure everything is good when i re install. dont want to strip out the splines or ruin the rear diff. any certain way its supposed to go back together would be greatly appreciated : ) thanks! Link to comment Share on other sites More sharing options...
Caliber308 Posted July 1, 2013 Report Share Posted July 1, 2013 (edited) so while installing my rear struts and springs the cv axles where its splined had pulled out from the rear diff. do i just push them back in and make sure that they are pushed in all the way when i bolt everything back together? i see that theirs a c clip on the end of the splines of the cv axle. just want to make sure everything is good when i re install. dont want to strip out the splines or ruin the rear diff. any certain way its supposed to go back together would be greatly appreciated : ) thanks! Just push the half shaft back in. If the Oil Seal was leaking prior to this,Yes, install a new Oil Seal in the Differential. If not, leave it be, but monitor it on a continual basis for future leakage. Bill Edited July 1, 2013 by Caliber308 Link to comment Share on other sites More sharing options...
Shelby Posted July 3, 2013 Report Share Posted July 3, 2013 glad you asked this question now rather then after you snaped an axle shaft end off ,,like most do Link to comment Share on other sites More sharing options...
2fast2six Posted July 3, 2013 Author Report Share Posted July 3, 2013 LOL yea just wanna make sure all is good yea know!? so pretty much just push the axle shaft all the way back into the diff and i should have no problems? Link to comment Share on other sites More sharing options...
Shelby Posted July 4, 2013 Report Share Posted July 4, 2013 you got it, you may need to use a little force to get them incerted, so be careful not to damage the boots Link to comment Share on other sites More sharing options...
kev Posted July 9, 2013 Report Share Posted July 9, 2013 Once you pop them in, pull on them a bit in attempt to pop them back out. You should have a pretty good resistance. If they just pop back out with ease, then your C-clip is shot. If the c clip is shot, the axle will pop out of position while driving and the rear will chew away the spline joint on the axle and render it useless. Believe me, been there, lol. oh and don't pull on the outer bolted/flanged hub. Pull from the axle itself (round bar) or the inner hub. kev Link to comment Share on other sites More sharing options...
