Starting my 2jz/R154 swap
RobH
  • Replies 90
  • Created
  • Last Reply
Top Posters In This Topic
couple more pics worked on it while i was waiting on parts for a dif car im working on
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0225.jpg
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0226.jpg
little update
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0231.jpg
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0230.jpg
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0229.jpg
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0228.jpg
and im still working on it
so the next step is to figure out where to run the harness threw the firewall
then what wires i need to hook up
help from any would would be much appreciated
thx for the help all
A BIG A+++ goes out to vettekiller for the motor mounts perfect fit well worth the dollars
Edited by RobH
There is a rubber grommet next to the brake booster on the firewall; left side of the tranny tunnel. Use that for your harness path. Its best to run the harness there since most plugs will get connect to the intake side of JZ motor, also less heat. Edited by DieHARDmitsu.
not sure if you done this already but now would be a great time to take down the oil pan clean and re seal it. Also, change the front and rear seal on the motor.
DONE
along with cam seals water pump hydrolic tensioner tensioner pulley and timing belt and valve cover gaskets oh and thermostat
Edited by RobH
Boho,
Just pick up a nice 2JZ GE bottom end. swap that out with your bottom end and swap your 1jz pistons to the 2jz bottom end. Pistons are the same between engines. You can probably find a nice 2jz ge bottom end for a couple hundred. That's the route I'm taking.
