underpaidslave Posted July 17, 2010 Report Share Posted July 17, 2010 hey im about to wire up these clips i bought from randy/dad and well there's two wires does it matter what wire goes to what wire? just dont want to get them backwards and cause further damage Link to comment Share on other sites More sharing options...
ucw458 Posted July 17, 2010 Report Share Posted July 17, 2010 (edited) There is no polarity on them. It doesn't matter. Just don't mix up the primary injector wires and the secondary injector wires. To be clear yer there is a pos and neg wire but the injector doesn't care if you reverse them. It will work fine. Just replace one clip at a time and you should have no problems. Be sure to solder them in or you may get problems down the road. Edited July 17, 2010 by ucw458 Link to comment Share on other sites More sharing options...
importwarrior Posted July 18, 2010 Report Share Posted July 18, 2010 i just did one wire at a time. for each clip. Link to comment Share on other sites More sharing options...
underpaidslave Posted July 18, 2010 Author Report Share Posted July 18, 2010 (edited) im 99% sure i didnt mix up the primary and the secondary. sodering in that tight spot was a complain for sure lol at auto edit cmon guys! Edited July 18, 2010 by underpaidslave Link to comment Share on other sites More sharing options...
starzky Posted July 28, 2010 Report Share Posted July 28, 2010 Guys!!!!Check these Bosch type Injector Clips with boots, Nice and Neat! Link to comment Share on other sites More sharing options...
BrazilBoy Posted July 28, 2010 Report Share Posted July 28, 2010 Guys!!!!Check these Bosch type Injector Clips with boots, Nice and Neat! Where did you snag those man....and do you have a part number? Link to comment Share on other sites More sharing options...
Alsandr Posted July 28, 2010 Report Share Posted July 28, 2010 I know PQ is a bit crazy, but didn't he say not to use those ones because they crack the injector? Square corners on clip + round corners on injector = bad news. Link to comment Share on other sites More sharing options...
Preludedude Posted July 28, 2010 Report Share Posted July 28, 2010 How can you tell the difference in the clips? i mean primary clip, secondary clip...they dont look alike? Link to comment Share on other sites More sharing options...
Cobalt60 Posted July 28, 2010 Report Share Posted July 28, 2010 im 99% sure i didnt mix up the primary and the secondary. sodering in that tight spot was a complain for sure I might be the only one whos done theirs this way, but I didnt solder mine. BTW, Im a professional electronics technician and I do surface mount soldering everyday, and own a nice solder station too. I just twisted the wires together, and used heatshrink tubing. The heatshrink tubing, if done right, can create an air/water tight seal, and thus prevent oxidation on the wires. My injector clips were done like this about a year ago and I have not had any problems, nor do I anticipate any. All that said, Im not saying soldering is a bad idea, just that its not necessary, at least in my case. -Chris P Link to comment Share on other sites More sharing options...
starzky Posted August 29, 2010 Report Share Posted August 29, 2010 I know PQ is a bit crazy, but didn't he say not to use those ones because they crack the injector? Square corners on clip + round corners on injector = bad news. Look closely..... they are rounded corners, same as original clips.I just doubled checked and compared them and saw the pictures from PQ site the bad clips have square corners/rectangular. Thanks for the warning!! Link to comment Share on other sites More sharing options...
