89 Quest Build Thread
Frenchi934
right now i'm waiting on weather... Might tint the fogs and stuff until I can paint. Should be good to go tuesday or weds...
Spoiler is ready for primer as are the headlight covers while the bumpers are ready for paint.
http://img413.imageshack.us/img413/5092/sdc11122k.jpg
http://img130.imageshack.us/img130/8347/sdc11121i.jpg
Since last update:
I rebuilt a tail light. If you're wondering how to do this first you pop these tabs.
http://img408.imageshack.us/img408/4655/sdc11123.jpg
Then using a heat gun or blow dryer you heat up the perimeter if the clear outer piece and pry the lens apart starting here:
http://img251.imageshack.us/img251/5750/sdc11124p.jpg
After its apart its pretty straight forward.
http://img228.imageshack.us/img228/263/sdc11125v.jpg
http://img706.imageshack.us/img706/4461/sdc11127s.jpg
Clean the lens, remove the old sealant, and repaint the rusty bits...
http://img225.imageshack.us/img225/5395/sdc11129f.jpg
Then re-assemble. I used this sealant and also sealed the bulbs from the back with it (suspected cause of original rust). I used it on my home made door panel seals too.
http://img256.imageshack.us/img256/9019/sdc11134.jpg
Good as new: except the cracks....
http://img704.imageshack.us/img704/5237/sdc11135p.jpg
Primered the air dam and the headlight covers.
http://img825.imageshack.us/img825/2623/sdc11131.jpg
http://img222.imageshack.us/img222/8694/sdc11133q.jpg
And got the header panel ready for dent repair:
http://img547.imageshack.us/img547/2317/sdc11132d.jpg
I also wanted to tint my fogs, so I went ahead and did it.
http://img571.imageshack.us/img571/1209/sdc11130.jpg
Edited by Frenchi934
Big day. I woke up early, primered the header panel, and then sealed up everything.
http://img510.imageshack.us/img510/8448/sdc11138.jpg
My dad made me this hook I can use to keep the panels from rocking from the air pressure:
http://img530.imageshack.us/img530/2037/sdc11139e.jpg
I also repainted (entirely) both bumpers and the splash panel and added support to the header panel.
http://img834.imageshack.us/img834/6199/sdc11140p.jpg
http://img707.imageshack.us/img707/4382/sdc11143m.jpg
Yes the back side of the header panel has runs, no I dont care haha..
Got to wet sand the sealer tomorrow with 600 grit just to scuff the surface. Should be able to paint saturday (fingers crossed)
bahaha. That isnt tape its a stick on fiberglass board. Although..with primer on it it looks just like duct tape...I put one on each side right in the middle of the span between the supports and it actually stiffened it up quite a bit. I guess you'll have to take my word for it. Edited by Frenchi934
I painted my last blue today. Very excited to move onto final assembly. All i have to do now is paint the grille, the headlight bezzels and foglight trim black, restore a couple brackets for bumper covers and assemble. Should be less than a week left on this thing.
Wow frenchi, I am very impressed. I just read through this whole thread all the way from day 1. I am glad there is someone in this world that will take the time to do things right. Your car definatly has show car quality work. Keep up the exceptional work. I love the color you chose and I am doing a similar color on my 71 El Camino. I look forward to seeinig your car in person. After I finish up my MPI conversion I want to take some road trips. Your house will be on my list of places to visit if that's ok with you.
Began fitting the bumper covers:
http://img526.imageshack.us/img526/6154/sdc11149d.jpg
Painted all the bracketry:
http://img534.imageshack.us/img534/7168/sdc11151q.jpg
Had to re-build this bracket...
http://img28.imageshack.us/img28/9877/sdc11152.jpg
http://img840.imageshack.us/img840/7590/sdc11153h.jpg
http://img214.imageshack.us/img214/8973/sdc11161p.jpg
mounted up the rear bumper:
http://img222.imageshack.us/img222/5513/sdc11158.jpg
On to the front: sprayed the headlight bracketry:
http://img402.imageshack.us/img402/9761/sdc11159e.jpg
Mounted everything on there and got the panels to fit correctly...
I decided to upgrade my lights too, also got real yellow h3 bulbs
http://img220.imageshack.us/img220/4866/sdc11169.jpg
http://img529.imageshack.us/img529/6533/sdc11171e.jpg
http://img819.imageshack.us/img819/865/sdc11173u.jpg
http://img513.imageshack.us/img513/5261/sdc11174i.jpg
http://img842.imageshack.us/img842/1175/sdc11175q.jpg
http://img600.imageshack.us/img600/2343/sdc11176.jpg
http://img140.imageshack.us/img140/2189/sdc11177s.jpg
Painting the grille tomorrow, then fin.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
