ScooterDude92
Restricted Member-
About ScooterDude92
- Birthday 06/30/1991
anything with a motor or wheels mostly starquests
kingsport, tennessee
37663
ESI-R
Eiger Silver
ScooterDude92's Achievements
my lifters tic sometimes, always at startup, just wandering what would cause hydrolic lifters to tic
my gaudge cluster lights and dash lights dont work ..the tailights do work, havac contros work but do not light up, i hooked a radio up today and sombody had cut the original connectors off and i had to go threw and figure them all out, only 4 speakers work dash and 2 back ones, door speakers also dont work thanks -curt
karma kicks my arse all the time man...one time bad karma pushed my 87 conquest off a hill yup that happened still hard to beleive it myself...but any way, my auto tranny acts like it dosnt go into 2nd and to shift to what should be 2nd from first i have to either let of the gas or hold it steady for a LONG time if i pull 10lbs at wot to 5k it will NOt s*** to second unles i let completly off the gas..not only that but i think its not second cause it bogs down to much after it does shift, now sometimes if i lightly let of the gas ital shift to what i think is really second cause it only moves down about 1500 rpms also park is way above park..reverse is at park and so on so forth
front end has a little wobble while breaking and moans a little while turning to the right only it seems like the tires seem to shake side to side, took the tirres off checked the wheel bearings and their good
al of that stuff is hookj up properly, i wanted to get it running perfect stock before i started to mess with anything
awsome thanks to browsing and seeing indianas older posts i thought heck i mise well try swapping the ecu out...i did and vaala runs perfect, i do have a little miss when boostin randomly but i was looking under the hood at night and i saw a spar around cylinder 3-4 so new ngks tomm and thatl be fixed im happy as hell
i chaged the ecu randomly today to a 87 ecu and my problem is FIXED!!! i dont know why the 88 ecu wasnt working correctly although i wish it was my problem is now fixed and im happy as hell ... since my 88 is a automatic and i took the ecu from a manuel isnt their a wire i have to repin?
put a injector from my 86 in as a secondary an it changed the condition some but syill breaks up a little... so im gonn order a set of delphies from the gp ill update this after i get the injectors and see what happens
i put my injectors in another car and they work perfect..im gonna go pressure test my ic piping now..maybe jus take them all out n check them
i did a tps/isc reset today and still doing the same stuff..ive noticed somthing else to after driving at night i can look at the turbo and the entire manifold/turbo hot side/ half of down pipe is red, so i thought well i bet the cats are cloged...took the exhaust back off and the cat under the car was already gutted and the dp cat was not i gutted it clean and reinstalled..it still turns the same amount of red i bought a new on frame fuel filter..i checked the in tank filter it was good and not to mention this cars tank is the cleanest ive ever seen on any starquest.. still no changes well what should i try now?
it reads just under 16v im gonna pull the in tank filter in a min..
sorry busy day man...so i replaced the mas with a known good one all my signals are working and guess what....same problem
how do i check that lol, ill jus swap a couple different ones in
ok i dont know if this has anything to do with it but when i turn my turn signals on they simply light up they dont blink,
i got new clips part number 85850 ones to, the injectors dont leak and spray correctly i cant think of anything else to check lol
