OPTIMUSPRIME Posted June 9, 2010 Report Share Posted June 9, 2010 Wondering if someone has done this?Just buying the 18G wheel, replace the 12A and machine the stock comressor housing to fit the larger wheel? would the walls of the entrance of the housing be to thin? Not sure whats the biggest wheel to use on the stock housing. if not then what housing would I need to keep the stock IC hoses and accordion hose? whant to keep the factory look. Link to comment Share on other sites More sharing options...
Laodicea Posted June 9, 2010 Report Share Posted June 9, 2010 Wondering if someone has done this?Just buying the 18G wheel, replace the 12A and machine the stock comressor housing to fit the larger wheel? would the walls of the entrance of the housing be to thin? Not sure whats the biggest wheel to use on the stock housing. if not then what housing would I need to keep the stock IC hoses and accordion hose? whant to keep the factory look. Yes this is what an 18g is...your 12a machined out. etc etc...make sure you get your turbo balanced with the new wheel. I may have left some info out...so anyone who wants to jump in and correct me please do. Link to comment Share on other sites More sharing options...
ragdoll_unlimited Posted June 9, 2010 Report Share Posted June 9, 2010 you have to do a step style machining. if you do a straigh bore for the size of the inducer on the compressor wheel it will break the housings, you have to do a partial step on the intake tube about halfway down. then where the metal gets thicker you can step the machining out and bore to the size of the inducer. its alot of work and takes alot of patience. in my best opinion its not worth it, just go with a evo3 16g and you will be more than happy. Link to comment Share on other sites More sharing options...
RF600 Posted June 10, 2010 Report Share Posted June 10, 2010 Get a 14b comp housing. If you looked at the insides of the 12a and the 14b side by side you would want the 14b. Link to comment Share on other sites More sharing options...
OPTIMUSPRIME Posted June 20, 2010 Author Report Share Posted June 20, 2010 How about this....Turbo Compressor Housing TD05H + Wheel 18G Link to comment Share on other sites More sharing options...
OPTIMUSPRIME Posted June 21, 2010 Author Report Share Posted June 21, 2010 (edited) How about this....Turbo Compressor Housing TD05H + Wheel 18G Would this work with the stock Turbo?Having it balance - re builtjust swap compressor housing and I guess i'll need the adapter to fit the hose on the 2 boltsLooks like this is a 14B housing right?! Edited June 21, 2010 by OPTIMUSPRIME Link to comment Share on other sites More sharing options...
h3r3tic Posted June 24, 2010 Report Share Posted June 24, 2010 Ragdoll did the 18g in a stock housing for my car and I think its awesome lol. I recommend him if he has the time. Link to comment Share on other sites More sharing options...
OPTIMUSPRIME Posted June 25, 2010 Author Report Share Posted June 25, 2010 actually this one... Link to comment Share on other sites More sharing options...
movin on Posted June 25, 2010 Report Share Posted June 25, 2010 How is the spool on that animal of a turbo? Link to comment Share on other sites More sharing options...
h3r3tic Posted June 25, 2010 Report Share Posted June 25, 2010 spool is fast right there its only at like 8 lbs right now but its full by like 2600 Link to comment Share on other sites More sharing options...
Laodicea Posted June 25, 2010 Report Share Posted June 25, 2010 You don't have an 18g then..sounds like the 12a still to me...My 18g was from Trilogy turbos and my car was modded to the T and mine would get full boost at 3500 like 10 lbs. But hey maybe I am wrong...I just know mine was way laggy after 18g went in. Link to comment Share on other sites More sharing options...
OPTIMUSPRIME Posted June 25, 2010 Author Report Share Posted June 25, 2010 ok, just found the place to upgrade my 12A to 18G Link to comment Share on other sites More sharing options...
h3r3tic Posted June 25, 2010 Report Share Posted June 25, 2010 Its deff not a 12a you can see the wheel size difference. Look at how much its ported. http://i620.photobucket.com/albums/tt283/h3r3tic/cid__downsized950522001703.jpg Link to comment Share on other sites More sharing options...
Laodicea Posted June 26, 2010 Report Share Posted June 26, 2010 Its deff not a 12a you can see the wheel size difference. Look at how much its ported. http://i620.photobucket.com/albums/tt283/h3r3tic/cid__downsized950522001703.jpg It is just my luck to always get something with the most lag and others get a benefit. Link to comment Share on other sites More sharing options...
Shelby Posted July 12, 2010 Report Share Posted July 12, 2010 a slight loss in spool time is always gona be the off set of going to a larger turbo compressor wheel,, from what i have learn'd most mits turbo's use the oem 12a compressor houseing all the way up to the 18g,, after that you use a 06 compressor houseing so the 20g wheel will fit , useing a larger exh turbine 05H can help with the spool up over the 05 oem houseing ,, the houseing can port'd to except the 05H exh wheel , the larger wheel can help the spool time on the lower end,, the problem is engine cid and volume of air flow,,at lower rpms the engine simply does not flow enought air to spool the larger turbine untill 2000-2500 rpms ,smaller exh turbines spool quicker cause they need less air flow but do not have room for high rpm exh flow , also note that higher engine rpms and add'd boost requires the exh waste gate passages be port'd to alow the increase 'd air low thru the exh houseing when useing a biger hot and cold side turbine Link to comment Share on other sites More sharing options...
ultraflexxj Posted July 19, 2010 Report Share Posted July 19, 2010 if you want an 18g out of the 12a housing, send your turbo to forcedperfromance.net Link to comment Share on other sites More sharing options...
Laodicea Posted July 19, 2010 Report Share Posted July 19, 2010 if you want an 18g out of the 12a housing, send your turbo to forcedperfromance.netYeah send it there...FP is right down the road frrom me. Or send it to Trilogy Turbos in FL. Link to comment Share on other sites More sharing options...
