Roller Camshaft Discussion - Data Collection
84 replies to this topic
#61 mstieg
mstieg
  • 6,179 posts
Posted 10 July 2016 - 12:03 AM
View PostTim_C., on 06 November 2015 - 01:38 PM, said:
The Aussie rocker works, but is a 1.55 or so ratio. It is between the 2.0L SOHC 1.5 ratio, and the V6 1.6 ratio. I'm sure the Aussie cam will work with a 1.6 ratio rocker, but it was close and I didn't feel like trying it since I had the 1.55 Aussie rockers with the cam. It seems to me that you are trying to re-invent the wheel when there are good options out there already, unless you want to spend the cash to make your own custom grind....
...Doing business properly seems to be a lost art with these new boys trying to build cars. Again, good luck, you are going to need it.
To the first part, back when I got my Magna cam & Magna rockers from Tim, we discussed the possibility of the 1.6 rockers not fully closing - to which I have also experienced.  That makes 3-4 of us now who have proved that to be the case.
To the second comment, having spoken with Tim several times and corresponded with Kev on here, I truly believe you both are knowledgeable and have the best of intentions for this group and these cars.  I'd hope things can be assumed as such and past errors made right to the extent they can be.
To the technical end:
Couldn't you just have the valves tips ground slightly if you really want the 1.6 rockers to close?
The BEST but also pricey experimental option is of course to make a roller rocker into adjustable mechanical not hydrolic.  Been discussed in the past.  Unfort the expense to have it done right is too high while the market is too small as I also found with attempts to help others with copying the updates needed to get the T56 swap plate & mounts to work.
Best wishes all.
Hopefully the few OEM Magna cams remaining are still in good shape.  I'd hope those don't get ground up.
Edited by mstieg, 10 July 2016 - 12:04 AM.
In Progress: breakin & tune
#62 psu_Crash
psu_Crash
  • 7,210 posts
Posted 24 April 2018 - 09:43 AM
FYI
I bought the RPW cam setup from Mach5 and have it running in the car. Free revs just fine and smooth.
Although i haven't drove it yet since I screwed something up with the fidanza and new clutch install... I'll report back when I do. Planned to hit the dyno on friday, but without a working clutch. Time will tell
The Valencia Project
My Feedback Link
#63 kev
kev
    Moderator
  • 5,021 posts
Posted 26 April 2018 - 06:39 AM
Cool!  I was hoping someone would snag that thing.  Let us know how it performs.
#64 Mach 5
Mach 5
  • 508 posts
Posted 04 May 2018 - 09:05 PM
how does it sound?
Owner- Radical Revs Auto- Jarek-
-Rides-
-1987 Starion -Midnight Star - FORD BARRA GTX4508r Build Progress see link
http://www.starquest...howtopic=152434
-1989 Chrysler Conquest-Track Beast Mode gtx3071r TBI 365hp 407tq @19psi/ 401hp 430tq @ 24psi sold
http://www.starquest...ic=151885&st=40
-1989 Pontiac Grand Prix Turbo SE- 3.1 gtx3582r getrag284 Tilton twin disc
-1991 Toyota Hilux Pickup 1uz itb cp pistons kelford cams TripleR head porting/ long tubes
-1986 AE86 20v.. 171hp@ 8200rpm
#65 Mach 5
Mach 5
  • 508 posts
Posted 04 May 2018 - 09:06 PM
need to post video. im curious
-Rides-
#66 psu_Crash
psu_Crash
  • 7,210 posts
Posted 04 May 2018 - 10:06 PM
https://www.facebook...57767807610369/
On the dyno today. This cam works very well! Peaked at 368/406. Tweaked a bit and settled at 360/400 @18psi
Runs 2 and 3 were 12psi or so playing with things. Run 1 was 18psi after some timing work. I didn't run the meth injection and didn't really push it. The goal was 350/400 at reasonable boost. No problem
Very happy with this!
My Feedback Link
#67 Mach 5
Mach 5
  • 508 posts
Posted 04 May 2018 - 10:37 PM
I wonder what it would do on a head that wasn't ported. I ported the head for my tbi car a similar way I did that one and it did okay. do you have a dyno graph/ video? how did it come on to boost?Im glad your happy with itedit I see the link.. maa bad ;)
Edited by Mach 5, 04 May 2018 - 10:38 PM.
-Rides-
#68 Mach 5
Mach 5
  • 508 posts
Posted 04 May 2018 - 10:45 PM
how does this compare to the last setup you had?
-Rides-
#69 psu_Crash
psu_Crash
  • 7,210 posts
Posted 05 May 2018 - 08:29 AM
It puts down more power at less boost and the curves are much smoother. Not really apples to apples though. This was a pro tune. The last setup was tuned without a dyno by yours truly. I haven't drove it since getting tuned either. I'll be going for a test run very soon :)
Im very happy with the numbers it put down. Not bad for a $120 ebay turbo. Probably would have been a 400hp pull on a Dynojet. I intend to find out
Edited by psu_Crash, 05 May 2018 - 08:32 AM.
My Feedback Link
#70 mstieg
mstieg
  • 6,179 posts
Posted 07 August 2018 - 03:53 PM
bump for good stuff.  If cleaner, some of this could be worth a sticky.  I understand warning people about less than honest cam providers though.  Maybe move those posts to a new thread in the Feedback Forum?
Edited by mstieg, 07 August 2018 - 04:09 PM.
#71 kev
kev
    Moderator
  • 5,021 posts
Posted 21 August 2018 - 09:15 AM
Feel free to consolidate the info you feel is faq worthy in a single post and I'll copy it over the faq forum.
I already tried cleaning this thread up once before and renamed it accordingly.   There are many topics discussed in here all relating to roller cams in general.  Lots of good information but still lots of holes.  For instance, I'd love to find out the actual part numbers for the magna camshafts.  I'm surprised none of our AU members have provided parts manuals, etc.  It would be some great info to have.
#72 psu_Crash
psu_Crash
  • 7,210 posts
Posted 14 April 2019 - 08:53 PM
Well I hate to report that the RPW cam setup has some kind of problem. I ran it all last race season with zero issues .. that I knew of. Got the car out for opening weekend at the Glen and it was ticking. Thought I had a sticky lifter. Come to find out the top of the valves had mushroomed to some extend on all of them. One was worn right into the keepers. I don't know what the issue is and with this amount of damage I'll have to remount it in my test head and do some research.
My Feedback Link
#73 Funky Phil
Funky Phil
    Super Pooper
  • 6,446 posts
Posted 16 April 2019 - 09:31 AM
Float, they all float down here.......-pennywise
Edited by Funky Phil, 16 April 2019 - 09:32 AM.
#74 psu_Crash
psu_Crash
  • 7,210 posts
Posted 16 April 2019 - 10:11 AM
Nice one Phil. So let's say I'm brave and give it another go with beehive springs. It was a great running cam with a wonderful power curve. RPW recommends their dual spring
My Feedback Link
#75 speedyquest
speedyquest
  • 4,193 posts
Posted 16 April 2019 - 10:16 AM
Do you think the beehive springs were the culprit?
#76 psu_Crash
psu_Crash
  • 7,210 posts
Posted 16 April 2019 - 12:37 PM
No. I was running Isky springs
My Feedback Link
#77 speedyquest
speedyquest
  • 4,193 posts
Posted 16 April 2019 - 01:16 PM
Ok, I ask because I'm about to upgrade to beehive springs. I'd have been concerned if you had said otherwise.
#78 psu_Crash
psu_Crash
  • 7,210 posts
Posted 16 April 2019 - 06:38 PM
Ordered the beehive springs. Decided I'll give the roller another go. This time I'll make sure to have proper seat pressure. What do you think is a good number to shoot for. I'm thinking 130 on new springs.
My Feedback Link
#79 starquestJOE
starquestJOE
  • 3,563 posts
Posted 16 April 2019 - 07:14 PM
Why not go with a dual spring set up like i run. My valves with never float lol
And know that i think about it i gave you a roller set up when i bought this head. I had plans to run mechanical the whole time. I wonder the reason i have dual spring was for correct seat pressure with the roller set up?
Edited by starquestJOE, 16 April 2019 - 07:21 PM.
IM STARQUEST 4 LIFE ....
88 esi-r-white-SOLD
88 tsi white 61k-SOLD
89 tsi-black-rip
87 tsi-black/red-SOLD
88 tsi yellow sold
89 tsi white parts car
88 esi-r-black-RIP
#80 psu_Crash
psu_Crash
  • 7,210 posts
Posted 16 April 2019 - 08:33 PM
That would make sense. Hoping I can get the beehives to do the trick. I believe that's what funky uses. Although this cam has a pretty high lift so that might make a difference. O.318 lift at the cam times 1.55 is 0.493 might be better off using the 1.5 rockers for this. I have some work to do
I'll try to find some time to start my own thread with all the details and pictures of my adventure
Edited by psu_Crash, 16 April 2019 - 08:34 PM.
My Feedback Link
