Starionboy84 Posted December 15, 2013 Report Share Posted December 15, 2013 I cant get mye rear spoiler off. How do I get it off? Is there any hidden bolts? Is it glued to the hatch?Anyone know where I can get a new/used one? Link to comment Share on other sites More sharing options...
BC_99 Posted December 15, 2013 Report Share Posted December 15, 2013 You have to pull the interior trim out to get to the nuts. BC_99 Link to comment Share on other sites More sharing options...
ucw458 Posted December 15, 2013 Report Share Posted December 15, 2013 Under the plastic trim on the inside are the bolts holding it on. There is tape covering some of the bolt holes. The spoiler is 2 pieces. The upper rubber one easily unbolts. The lower fiberglass part is glued to the glass. Link to comment Share on other sites More sharing options...
LEPORE Posted December 15, 2013 Report Share Posted December 15, 2013 what is your location? Link to comment Share on other sites More sharing options...
techboy Posted December 17, 2013 Report Share Posted December 17, 2013 I tried to take one of these off before too, it's not easy. The spoiler actually bolts through the hatch glass, and when you undo the bolts, some of them have these large washer things that are attached to the glass with an adhesive. I actually ended up braking the glass trying to do it. Lesson learned - I won't do that again. I even ended up throwing the spoiler out b/c no one on here wanted it ... lol. Link to comment Share on other sites More sharing options...
JohnnyWadd Posted December 17, 2013 Report Share Posted December 17, 2013 (edited) I have done 3 of them. There are two allen head bolts on either side , they are slightly hidden. I used a allen wrench that was trimmed down with a cut off wheel to get in there. Loosen at the hold down nuts first. I butter knife is a great tool or a old butcher knife. Use a torch or heat gun to heat it up and slide it between the spoiler and glass for cut the adhesive. sharp thin knife, like a filet knife, and gentle heat makes it much easier. Its not so bad. Use an old butter knife sharpened with a file and work it under and all the way around. Do it on a hot day it goes way faster or use heat on the knife. Work around the spoiler WITHOUT prying until all the adhesive is cut. You can tell because the knife will go in anywhere without too much resistance. After all that you will be able to lift it off there from either side. Of course loosen all fasteners first. For the hex keys on the side I used allen wrench that was cut down to fit in the small recess. Edited December 17, 2013 by JohnnyWadd Link to comment Share on other sites More sharing options...
jjohnson Posted December 17, 2013 Report Share Posted December 17, 2013 After I too off all the nuts and it there was 2 hidden under tape then I sharpened a flexible scraper and cut the double stick tape along the front and back to get the spoiler off . Link to comment Share on other sites More sharing options...
