Lizzord30 Posted May 29, 2012 Report Share Posted May 29, 2012 So lets see them! Prefer ones are dyno tuned, but all accepted if the car is running well! Link to comment Share on other sites More sharing options...
scott87star Posted May 29, 2012 Report Share Posted May 29, 2012 I'm sure if you search you'll find more than you need. Link to comment Share on other sites More sharing options...
19cturbo Posted May 29, 2012 Report Share Posted May 29, 2012 There is a post at the top of the MPI section with this stuff in it. Also someone elses setup is not going to run your car perfect even if they are the exact same and dyno tuned. youll need something for your car. Link to comment Share on other sites More sharing options...
Lizzord30 Posted May 29, 2012 Author Report Share Posted May 29, 2012 Actualy very little people have posted their maps (yes I have looked and found maybe 3) We need a resource for alot of different ideas for what works well for the g54b MPI, With enof we can maybe find what works best and what doesnt work. Looking for a trend is moring then just getting a setting then saying ok done. Stock TBI ignition map isnt necessarily the best for the mpi, with mpi have ablity to have map go anyway want. If you have done enof tuning you will know its more of an art then science to get it perfect. Link to comment Share on other sites More sharing options...
Skippy Posted May 29, 2012 Report Share Posted May 29, 2012 If you have done enof tuning you will know its more of an art then science to get it perfect. I don't know jack about tuning, but would guess the quote above is the reason people don't post them here and why a tuner would say it isn't cookie cutter and should be done individually on a car by car basis. Link to comment Share on other sites More sharing options...
Lizzord30 Posted May 29, 2012 Author Report Share Posted May 29, 2012 The Idea is to create a resource for information. Doesn't mean your car will be same as this or that car. But if we notice a tread like every car with XX style of tuning is making more power down low or up top it can help find the best for each car individual. Frankly I am shocked for the negative feedback on a idea to help the overall group of StarQuesters. Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted May 29, 2012 Report Share Posted May 29, 2012 This is not how I feel, but I believe that many people with fully tuned quests don't want to just give away their tune information because they either payed for it or worked many hours getting it right and they feel that others shouldn't be able to have it for nothing. It's sad, but it's true. I know that when I get my car running, I'll be sure to post my tune up for all to see. There are many benefits to that as some more experienced members may spot issues. 1 Link to comment Share on other sites More sharing options...
ESIrType? Posted May 29, 2012 Report Share Posted May 29, 2012 There aren't many ign maps posted. It would be nice to have more out there. Like you said maybe xx maps makes more down low and xx makes more on the high. I can post my old maps if you want. They aren't dyno tuned and are very modest on timing. I had a more aggressive tune but it wouldn't spool. I redid it and it was a HUGE difference. After this I never spent time dialing it it.I would like to see more maps for the good of the community. Shawn Link to comment Share on other sites More sharing options...
ESIrType? Posted May 29, 2012 Report Share Posted May 29, 2012 (edited) Ok here's mine and my setup. stock bottom end with BSE274h Cam1mm undercut valves3" DP2.5" exhaustEqual length headerHolest HY352.5" IC piping12"x24"x3" IC coreMPI (MX6 intake about 14" runners)65mm TBEDIS coil (wasted spark) with direct drive from the MegasquirtMegasquirt 3.0 with MSnS75lbs injectorsAlso running 20psi http://i1128.photobucket.com/albums/m500/esirtype/Starion/ign-table.jpg Shawn Edited May 30, 2012 by ESIrType? Link to comment Share on other sites More sharing options...
19cturbo Posted May 29, 2012 Report Share Posted May 29, 2012 I suppose i can contribute to this madness here. Megasquirt MSII 3.57.Magna intake4x 75LB injectors (780cc)Ford Edis ignition systemGm coolant temp, and IAT sensor.Holset HX35 turbo20PSI3 Inch exhaust2.5 inch intercooler pipe29x11x3 intercooler This setup is running really well for me, its not 100% complete but very close. Work done by scott87star. Basic settingshttp://i223.photobucket.com/albums/dd23/19cturbo/MPI%20project/ENGINECONSTANTS.jpg Ignition tablehttp://i223.photobucket.com/albums/dd23/19cturbo/MPI%20project/IGNITIONTABLE.jpg Fuel tablehttp://i223.photobucket.com/albums/dd23/19cturbo/MPI%20project/FUELTABLE.jpg AFR tablehttp://i223.photobucket.com/albums/dd23/19cturbo/MPI%20project/AFRTABLE.jpg Accel enrichhttp://i223.photobucket.com/albums/dd23/19cturbo/MPI%20project/ACCELENRICH.jpg Warm up enrichhttp://i223.photobucket.com/albums/dd23/19cturbo/MPI%20project/WUETABLE.jpg Link to comment Share on other sites More sharing options...
ESIrType? Posted May 30, 2012 Report Share Posted May 30, 2012 Not trying to clutter the thread or be a post hog...but. 19cturbo, what cam are you running? Also where are you hitting 15psi and 20psi by? I am curious because our setups are close, but I'm running a little smaller hotside turbo. I had a map with more advance in the low boost like you and wasn't spooling to quick. Last I drove the car I was spooling 15psi by 2800-2900 rpms and 20-21psi by 3200 rpms. Shawn Link to comment Share on other sites More sharing options...
19cturbo Posted May 30, 2012 Report Share Posted May 30, 2012 Not trying to clutter the thread or be a post hog...but. 19cturbo, what cam are you running? Also where are you hitting 15psi and 20psi by? I am curious because our setups are close, but I'm running a little smaller hotside turbo.I had a map with more advance in the low boost like you and wasn't spooling to quick. Last I drove the car I was spooling 15psi by 2800-2900 rpms and 20-21psi by 3200 rpms. Shawn that sounds about how mine spools. thats pretty good for a big ole turbo.. Im also running a stock cam. scott87star is doing the tuning on mine. Link to comment Share on other sites More sharing options...
psu_Crash Posted June 2, 2012 Report Share Posted June 2, 2012 (edited) http://img718.imageshack.us/img718/9760/sparktable4152012.jpg Edited June 2, 2012 by psu_Crash Link to comment Share on other sites More sharing options...
Lizzord30 Posted June 2, 2012 Author Report Share Posted June 2, 2012 How much KPa is one psi? trying to make since of your maps. I look online and it says 10 is one psi does that mean for vac the MS always uses the same? Link to comment Share on other sites More sharing options...
psu_Crash Posted June 2, 2012 Report Share Posted June 2, 2012 10 kPa is 1.45 psi or 1psi is 6.9kPa also 1 bar is 100kPaI just round off to 1psi = 7kPa for tuning purposes.MS always references kPa. Atmospheric pressure is 101.325kPa at sea level. Anything above that will be less.For instance my barometric pressure at home today was 97kPa Link to comment Share on other sites More sharing options...
Lizzord30 Posted June 2, 2012 Author Report Share Posted June 2, 2012 Wow great guys! This is some great post, can see a big difference in the maps very interesting, Ill post my map once i get it tuned well. Link to comment Share on other sites More sharing options...
