How much tunnel work to fit a T-56 in a manual ?
#21
Posted 03 January 2012 - 02:53 AM
#22
Posted 05 January 2012 - 12:46 AM
http://www.starquest...showtopic=24651
#23
Posted 05 January 2012 - 01:08 AM
(edited again) It's Oct. and still no kit. No responses at all to PM, email, and even phone messages! - I was very polite btw Disappointing.
I'd really like to get this swap done and see what this setup is capable of!! (note Chad's MPI intake & equal length header are major components)
Edited by mstieg, 06 October 2012 - 09:36 PM.
In Progress: engine rebuild w/ Magna roller, reworked & ported AMC head, T56 swap, 4.22 rear, gas tank renewal, all gauges, steering lines & coupler fix also in works.
Future: ________
FOR SALE: spare distributor, NIB pair of beefy U-joints, etc. http://www.starquest...howtopic=133262 also Autometer gauge panel: http://www.starquest...pic=136703&st=0
#24
Posted 06 January 2012 - 02:18 AM
chads:
http://www.nwstarque...om/Dcp00726.jpg
mine:
http://s81.photobuck...nt=DSC_0971.jpg
I ended up lowering from this position about 1/2 an inch. But this is where the driveshaft appeared to be at the correct angle (3-5 degrees).
#25
Posted 06 January 2012 - 02:27 AM
TsTKl, on 06 January 2012 - 02:18 AM, said:
chads:
mine:
Am I missing something, or does this pic of Chad's not have the mount installed? It looks like it's half installed & sitting on a red jack, which would explain it being lower. You prob. meant to link to a diff pic?
Future: ________
#26
Posted 06 January 2012 - 07:50 PM
#27
Posted 06 January 2012 - 07:57 PM
http://www.nwstarque...om/Dcp00728.jpg
It's being held up by the motor only in this pic, no cross member, this happens because the custom intake I use only has a 1/4" clearance from the brake booster. with the transmission weight pulling on it, the motor rocks back till the intake hits the booster, then stops. with the cross member in there raising the motor back up, the transmission goes up another 1/4" - 3/8".
#28
Future: ________
#29
Posted 06 January 2012 - 08:06 PM
I know for certain of 3 installed/runing, but suspect 5 are actually in use.
PM Sent Matt
#30
Posted 06 January 2012 - 08:28 PM
I plan to just get a mechanical Autometer Speedo to mate up w/ the trans to avoid an equally expensive (or more) translator or work done to the trans to mate w/ stock gauge.
Any other of those trans sensors plugs needed/useful besides reverse light? I have one spot left in the 3 hole radio console plate for another gauge if practical.
Future: ________
#31
Posted 06 January 2012 - 10:02 PM
is the trans you have mechanical? most are electronic, though mechanicals do exist. you can also convert the tail housing to mechanical on pretty much any T56 model.
Tremec recently came out wtih a new aftermarket T56 that has mechanical as a stock feature, I'll likely upgrade to that one.
#32
Posted 06 January 2012 - 11:50 PM
Future: ________
#34
Posted 07 January 2012 - 12:30 AM
BOOSTED88tsi, on 07 January 2012 - 12:12 AM, said:
Same with analog speedos? I like seeing the needle flying around vs. digital #s changing. Plus all the others are analog.
Future: ________
#36
Posted 07 January 2012 - 11:01 AM
#37
Posted 11 January 2012 - 09:05 PM
just a reminder my t-56 is hooked up to a 4g63 not a g54b
#38
Posted 11 January 2012 - 09:29 PM
Edited by mstieg, 12 January 2012 - 02:03 AM.
Future: ________
#39
Posted 12 January 2012 - 02:03 AM
Thanks for the info on the pulse count. It should be the the same 7 pulses on a SQ regardless on engine however modified rear differential gearing will change that. I'll prob. have to change my rear diff for the T56 anyhow, but good to know about the calibration.
Future: ________
#40
Posted 17 May 2012 - 05:24 PM
89' Starion - Abused Crashed and sold good times though
87' Starion Parted out and crushed
Also tagged with one or more of these keywords: manual, t-56, t56, tunnel
StarQuest Bazaar →
eBay/ Craiglist notices and alerts →
Ls1 long block and msd carb conversionStarted by NW TSI, 30 Dec 2012 |
StarQuest Bazaar →
Parts for sale →
87 Transmission (Ohio)Started by jayfressh, 29 Nov 2012 |
