motor mounts and shifter relocaters
58 replies to this topic
#41 Frenchi934
Frenchi934
  • 2,747 posts
Posted 29 June 2011 - 10:31 AM
wow. As always, great work bill. You contribute a lot to this community.
My car on Racefriv.com
#42 euphoria
euphoria
  • 179 posts
  • Interests:My DSM, the beach, green paper, and my friends.
Posted 02 July 2011 - 09:47 PM
I'm in for a kit.
2008 Mercedes SL55 AMG
1998 Eclipse GSX - 611awhp (in the quest for 4 digit power)
1987 Conquest TSI - 2JZGTE (in progress)
#43 Bill Hincher
Bill Hincher
  • 827 posts
  • Interests:Busty big Gurls and small cars
Posted 14 September 2011 - 07:55 PM
this is the remote shifter, the first thing I did was replace the shifer loop extension with an R 154 internal set up
Posted Image  Posted Image
then I located and mounted the second peice from the R 154 shifter and located the shift rail
then I started building the body of the remote shifter
I could have done this a lot of different ways but it had to be very universal because it will fit a variaty of aplications and it had to work just as well as  a 5 inch extension to a 2 foot extension
  I will probably spend just as much time building the tooling to machine this part
#44 Funky Phil
Funky Phil
    Super Pooper
  • 4,019 posts
Posted 14 September 2011 - 09:30 PM
bill, you work is amazing! I really wish youd release those mounts for the g54b.
As for the shifter relocation, why not just slice and relocate half the housing rearward and extend the shift lever? Thats how mine is. Its holding up, and I sure as hell dont baby shift.
Click pic for Build
#45 Bill Hincher
Bill Hincher
  • 827 posts
Posted 14 September 2011 - 09:58 PM
  the Subaru guys are replacing the RX 7 engines with sub turbo units and using my bellhousings for tthe W series Toyota trans for RWD set ups and the shifter needs to set back 12 inches, so I need a longer extension then just a longer loop, so I am building this 'box' so I can use either a solid shaft or cables if needed
  anyway, its a nice remote shifter for a veriaty applications
#46 Bill Hincher
Bill Hincher
  • 827 posts
Posted 28 April 2012 - 09:42 PM
I built my own transmission jack by combining my C frame ( because I am cheap )  >;o)
  I had to build a rear transmission mount for both the W series and the R series toyota transmissions to the Conquest
#47 screemin eagle
screemin eagle
  • 682 posts
Posted 19 May 2012 - 09:59 PM
Bill that thing is sweet when can I get one?
88 TSI 4g63
03 GMC Denali the tow truck
#48 BOHO
BOHO
    Sucks at life
  • 4,390 posts
Posted 19 May 2012 - 10:28 PM
I would buy that trans mount also...lol
87 Starion 2jz
#49 Bill Hincher
Bill Hincher
  • 827 posts
Posted 20 May 2012 - 09:54 PM
I got a bunch of housings to build but as soon as I can I will knock a couple out for you guys, no problem
this will fit both the w series and the R 154 seres transmissions
Edited by Bill Hincher, 20 May 2012 - 09:58 PM.
#50 BOHO
BOHO
    Sucks at life
  • 4,390 posts
Posted 20 May 2012 - 09:57 PM
How much would it cost Bill?
Can I see the mounting position a little better too? Mine would be a little different per the JZ. Just want to see if I could still make it work.
Edited by BOHO, 20 May 2012 - 10:03 PM.
87 Starion 2jz
#51 Bill Hincher
Bill Hincher
  • 827 posts
Posted 20 May 2012 - 10:13 PM
this one peice would at least put you in good position to build the rear mount,
but I put a lot of extra length in the rear lower mount so the trans can move an inch back and forth and still bolt up
#52 Bill Hincher
Bill Hincher
  • 827 posts
Posted 20 May 2012 - 10:14 PM
I will post some more pic's later when I build some, I gotta sleep >;o)
#53 Bill Hincher
Bill Hincher
  • 827 posts
Posted 01 August 2012 - 08:08 PM
I built another batch of rear trans mounts
#54 Big John
Big John
  • 207 posts
Posted 01 August 2012 - 08:56 PM
they look sooooo good i am ready and waiting thanks bill
#55 BOHO
BOHO
    Sucks at life
  • 4,390 posts
Posted 01 August 2012 - 09:27 PM
Awesome! In line as well!!
87 Starion 2jz
#56 button
button
  • 1,749 posts
Posted 02 August 2012 - 12:01 AM
Correct me if I am wrong, Bill, you are using standard off the shelf from every parts store gm trans mounts, right?
I like the way you do things.
-Jay
#57 screemin eagle
screemin eagle
  • 682 posts
Posted 02 August 2012 - 10:41 AM
Bill when can I place the order?
88 TSI 4g63
#58 Bill Hincher
Bill Hincher
  • 827 posts
Posted 15 September 2012 - 07:56 PM
I had to build a universal remote shifter that would fit both the W series and R series transmissions, so I used as many existing parts as I coould to hold the cost down
the rotation of the second shaft will be produced from the rotation of the shifter handle while the forward and back motion will be from the handle itself, the reason for that was because I had to have two seperate motion ratio's from the two seperate movements
the sideways motion through the 'gate' of the shifter can be adjusted by the hiegth of the two pivot points while the length of the 'throw' can be adjusted by the length of the shift arm
here you can see how the rotation to the right and then to the left works through  the pivot pionts
#59 BOHO
BOHO
    Sucks at life
  • 4,390 posts
Posted 15 September 2012 - 10:38 PM
You are a bad man.....
87 Starion 2jz
