motor mounts and shifter relocaters
58 replies to this topic
#1 Bill Hincher
Bill Hincher
  • 820 posts
  • Interests:Busty big Gurls and small cars
Posted 02 November 2010 - 09:28 AM
I was asked to build some  motor mounts for the 4G63 in the Conquest
I put a dummy 4G63 engine with an R 154 trans in place to check how it all fit
I re used the stock rear crossmamber with the toyota mount
I wanted to be sure to clear the first gen CAS system
I wanted to find the shifter location and fix that
  I know a lot of guys re used stock motor mounts but that dont make it the right set up
You have to measure the offset of the engine and find what is required to square up the system
after the measuring system is centered you can clearly see the offset at the rear
then the offset goes the other way at the trans output shaft
  i got to square the engine not only up and down but also sideways and the angle of the engine , so there is no twist, then the mounts can be built
Edited by Bill Hincher, 22 December 2010 - 05:26 PM.
#2 thagremlin
thagremlin
  • 1,602 posts
Posted 02 November 2010 - 10:25 AM
Wow nice an actual kit being made. Now only if you could do that for a 1jz/2jz engine with r154.
#3 freebird
freebird
  • 1,842 posts
  • Interests:time is of no moment, but only what your doing
Posted 02 November 2010 - 03:12 PM
In that last pic with the center of the crank shaft being measured.
What measurement from the face of the wheel hub to the core support do you have for the center?
This seems to be the best way to find center but I dont have these tools.
I just have string and chalk....or marker.
Did you happen to save any useable measurements on a notepad?
Even back at the firewall, trans tunnel shifter location.
Anything we can take note of that might help a man with no tools...lol
I know my swaps are nice and straight but it is nice to see if there could be a comparison.
#4 importwarrior
  • 10,259 posts
Posted 02 November 2010 - 04:12 PM
Can  not wait to see the end product!!!!!!!!
Edited by importwarrior, 02 November 2010 - 04:13 PM.
B-71 87 TSI  ~ RIP
#5 Bill Hincher
Bill Hincher
  • 820 posts
Posted 02 November 2010 - 04:52 PM
you buy the right book with the demensions so you can set your scale
  you can get them at any body shop supply house
#6 freebird
freebird
  • 1,842 posts
Posted 02 November 2010 - 06:31 PM
Awesome! never seen one before.
I have a copy of the frame chart saved
from kabamus garage site under the "best to use what you got first" link
http://www.kabamus.c...dex-frame1.html
But sometimes people get different #'s it's always cool to share #'s.
#7 Bill Hincher
Bill Hincher
  • 820 posts
Posted 02 November 2010 - 08:19 PM
   even a BLIND squirrel finds NUTS once  in a while :rolleyes:
#8 freebird
freebird
  • 1,842 posts
Posted 03 November 2010 - 07:19 AM
mmmm...nuts are everywhere but I keep chewing on pooo!
#9 Convette
Convette
    I used to driftjunk
  • 4,104 posts
  • Interests:Going faster
Posted 03 November 2010 - 11:46 AM
Damn. That woulda came in handy.  Your a genius Bill.
#10 Bill Hincher
Bill Hincher
  • 820 posts
Posted 03 November 2010 - 02:21 PM
  I'm liscensed but not practicing, right now I am in rehab
#11 Bill Hincher
Bill Hincher
  • 820 posts
Posted 07 November 2010 - 04:25 PM
Edited by Bill Hincher, 22 December 2010 - 05:27 PM.
#12 thagremlin
thagremlin
  • 1,602 posts
Posted 08 November 2010 - 12:53 PM
Would that mount kit fit a 2jz/1jz motor? How/where do you mount them?
Oh yea how much does that dimensions manual cost?
Edited by thagremlin, 08 November 2010 - 12:57 PM.
#13 importwarrior
  • 10,259 posts
Posted 25 November 2010 - 08:10 AM
any updates?  :unsure:
B-71 87 TSI  ~ RIP
#14 Bill Hincher
Bill Hincher
  • 820 posts
Posted 19 December 2010 - 10:10 AM
after I got pretty close to where it should be located, I built a little stronger mount using an angle iron and threaded rod so I could tilt the engine
Posted Image    Posted Image
you can clearly see what the problem was with the original engine mounts, the passenger side was so close it couldnt use the rubber cushion
just so we are all on the same page, this is located 2 inches ahead of the original location
I wanted a 2 degree slant towards the passenger side, so the engine tilts left
after measuring the drop in the driveline I found 1 to 2 degree was all I wanted in a tilt backwards
Edited by Bill Hincher, 22 December 2010 - 05:28 PM.
#15 importwarrior
  • 10,259 posts
Posted 20 December 2010 - 09:10 AM
Looking great so far. what transmission are you ging to be using?
and will this be the same mount used for the 2.4 wide block?
Thanks bill nice work.
B-71 87 TSI  ~ RIP
#16 BrazilBoy
BrazilBoy
    ^ Bird-Dog^
  • 9,745 posts
Posted 20 December 2010 - 09:31 AM
Can't wait for the end result..................
#17 SOTTY
SOTTY
  • 4,261 posts
  • Interests:Chrome @ polished aluminum
Posted 20 December 2010 - 07:07 PM
Always enjoy reading your threads Bill , excellent innovative work as always. :)
#18 Bill Hincher
Bill Hincher
  • 820 posts
Posted 20 December 2010 - 10:08 PM
Edited by Bill Hincher, 22 December 2010 - 05:29 PM.
#19 Bill Hincher
Bill Hincher
  • 820 posts
Posted 20 December 2010 - 11:01 PM
  the manuals cost a couple hundred for every year model, so you gotta buy one every year
#20 Bill Hincher
Bill Hincher
  • 820 posts
Posted 20 December 2010 - 11:02 PM
  Its the R 154 Toyota Supra Turbo trans mounted to a 4G63 narrow block
