SuperSteve57 Posted September 7, 2010 Report Share Posted September 7, 2010 What size boost gauge do i need too get to be able to replace the boost gauge in dash? thanks Link to comment Share on other sites More sharing options...
LEPORE Posted September 7, 2010 Report Share Posted September 7, 2010 52mm Link to comment Share on other sites More sharing options...
SuperSteve57 Posted September 7, 2010 Author Report Share Posted September 7, 2010 ok thanks. and is there any tips i need to know about installing it? Link to comment Share on other sites More sharing options...
mistapickles Posted September 7, 2010 Report Share Posted September 7, 2010 there will be blood....errr uh cutting... Link to comment Share on other sites More sharing options...
Indiana Posted September 7, 2010 Report Share Posted September 7, 2010 If you flush mount them after enlarging the opening a little it looks better than just sliding them in from the front. If left out the clear lense hits them and might crack. You can just mount it to the back housing. Remove the gauges if you grind the bits will cause them to stick. Razor blade the circuit board and just move the strips out of the way. There's as many ways to do this as there are gauges. You can also use black felt to hide the crack from the back so that no light escapes from the rest of the gauges. Very simple with a rotary zip tool. http://www.b2600turbo.com/images/bg02.JPGhttp://www.b2600turbo.com/images/bg03.JPGhttp://www.b2600turbo.com/images/bg04.JPGhttp://www.b2600turbo.com/images/bg05.JPGhttp://www.b2600turbo.com/images/bg01.JPG Link to comment Share on other sites More sharing options...
SuperSteve57 Posted September 7, 2010 Author Report Share Posted September 7, 2010 ^ ok thanks that helps alot. do you guys recommend any brand. or colors that look good with the stock dash colors? Link to comment Share on other sites More sharing options...
Caliber308 Posted September 8, 2010 Report Share Posted September 8, 2010 (edited) ^ ok thanks that helps alot. do you guys recommend any brand. or colors that look good with the stock dash colors? Autometer 2 1/16" Z series Boost/vacuum gauge. Summit carries them.Part no. ATM-2601. CALIBER 308 Edited September 8, 2010 by Caliber308 Link to comment Share on other sites More sharing options...
SuperSteve57 Posted September 8, 2010 Author Report Share Posted September 8, 2010 Any other ideas? Link to comment Share on other sites More sharing options...
89PalermoSHP Posted September 8, 2010 Report Share Posted September 8, 2010 thats a great idea Cal! Link to comment Share on other sites More sharing options...
Caliber308 Posted September 8, 2010 Report Share Posted September 8, 2010 (edited) thats a great idea Cal! Just telling it like I see it. Congrats on your 5000 posts. Starquestclub.com should give you a "Get out of banning free" card for one year. CALIBER 308 Edited September 8, 2010 by Caliber308 Link to comment Share on other sites More sharing options...
SuperSteve57 Posted September 9, 2010 Author Report Share Posted September 9, 2010 i was just asking any other members if they had any other gauges they may prefer. thank you 308 and i believe i did thank the member for there advice. so thanks. Link to comment Share on other sites More sharing options...
StallionProject86 Posted November 23, 2010 Report Share Posted November 23, 2010 If you flush mount them after enlarging the opening a little it looks better than just sliding them in from the front. If left out the clear lense hits them and might crack. You can just mount it to the back housing. Remove the gauges if you grind the bits will cause them to stick. Razor blade the circuit board and just move the strips out of the way. There's as many ways to do this as there are gauges. You can also use black felt to hide the crack from the back so that no light escapes from the rest of the gauges. Very simple with a rotary zip tool. http://www.b2600turbo.com/images/bg02.JPGhttp://www.b2600turbo.com/images/bg03.JPGhttp://www.b2600turbo.com/images/bg04.JPGhttp://www.b2600turbo.com/images/bg05.JPGhttp://www.b2600turbo.com/images/bg01.JPG Will this work for an 86' ? I'm in the process of swapping my turbo gauge but the circuitry looks different on the one you've done here. Any help would be great I'm stuck as is. Link to comment Share on other sites More sharing options...
SuperSteve57 Posted November 24, 2010 Author Report Share Posted November 24, 2010 yes it will work. you just have to cut around the ribbon. Link to comment Share on other sites More sharing options...
RF600 Posted November 24, 2010 Report Share Posted November 24, 2010 I have a Cobalt gauge in mine. I also have overlays for the rest of the gauges. Link to comment Share on other sites More sharing options...
