mopar jon Posted July 14, 2014 Report Share Posted July 14, 2014 I pulled apart a 1987 Conquest that i think has a 88-89 flywheel as the 6-puk clutch disc measures 9.5 inches. Does any one know the factory part numbers on the flywheels? Link to comment Share on other sites More sharing options...
tsi_tom Posted July 14, 2014 Report Share Posted July 14, 2014 (edited) SOS manual: http://starquest.i-x...er=asc&start=50 most of the way down Need to log in to see the pictures Edited July 14, 2014 by tsi_tom Link to comment Share on other sites More sharing options...
Dad Posted July 15, 2014 Report Share Posted July 15, 2014 Quick check is if the flywheel has a dowel hole for mounting to crankshaft. All 240mm flywheels have the dowel hole. 225mm do not. This is for stock flywheels Link to comment Share on other sites More sharing options...
mopar jon Posted July 15, 2014 Author Report Share Posted July 15, 2014 Thank You Dad, That was even easier then getting a part number, at least now i know its a 240mm, and can proceed.Thanks Again Link to comment Share on other sites More sharing options...
jszucs Posted July 15, 2014 Report Share Posted July 15, 2014 Thank You Dad, That was even easier then getting a part number, at least now i know its a 240mm, and can proceed.Thanks Again Might also consider tossing her on a scale and see if she was lightened.... I know that was pretty popular and heated debate around here back in the day. and guessing if they went puck disk they would have had it done when resurfaced but have seen way funker things done. Link to comment Share on other sites More sharing options...
mopar jon Posted July 15, 2014 Author Report Share Posted July 15, 2014 Might also consider tossing her on a scale and see if she was lightened.... I know that was pretty popular and heated debate around here back in the day. and guessing if they went puck disk they would have had it done when resurfaced but have seen way funker things done.Good Point as this was a former drag car and alot of mods were done to it. Link to comment Share on other sites More sharing options...
ucw458 Posted July 15, 2014 Report Share Posted July 15, 2014 Post a pic of the back and we can tell you if it was lightened. Link to comment Share on other sites More sharing options...
jszucs Posted July 15, 2014 Report Share Posted July 15, 2014 Post a pic of the back and we can tell you if it was lightened. Yeah they typically did it by drilling material out didn't they? Then drill more to rebal. So should be pretty evident. Link to comment Share on other sites More sharing options...
ucw458 Posted July 15, 2014 Report Share Posted July 15, 2014 No, turned on a lathe to lighten. Then drill on the edges to re-balance. Link to comment Share on other sites More sharing options...
mopar jon Posted July 15, 2014 Author Report Share Posted July 15, 2014 It weighs 35lbs, so its not been lightened Link to comment Share on other sites More sharing options...
