importwarrior Posted July 20, 2015 Report Share Posted July 20, 2015 just to compare the T3 drain flange to the T6 drain Flange. T3 http://i139.photobucket.com/albums/q299/I-W/Turbo/Turbo%20Drain/B57C3964-B904-4D80-B06A-9900FA97AA55_zpsopbyiv7o.jpg http://i139.photobucket.com/albums/q299/I-W/Turbo/Turbo%20Drain/6D95BEA8-B336-4744-ABC2-877720986BEE_zpstqcn84si.jpg T6 http://i139.photobucket.com/albums/q299/I-W/Turbo/Turbo%20Drain/B893FAB3-0DDB-496B-86FD-0C03594EB81D_zpsuufeb049.jpg http://i139.photobucket.com/albums/q299/I-W/Turbo/Turbo%20Drain/C4C5C341-678E-480E-B47A-BD7826E56656_zpsqabmshqn.jpg http://i139.photobucket.com/albums/q299/I-W/Turbo/Turbo%20Drain/88069B5B-6F8E-4A26-9DF4-AE186AFE99C7_zps37yufsja.jpg Link to comment Share on other sites More sharing options...
importwarrior Posted July 20, 2015 Author Report Share Posted July 20, 2015 T3 compared to T6 http://i139.photobucket.com/albums/q299/I-W/Turbo/Turbo%20Drain/DCCE042C-8CE1-4F28-B763-D9EEAD348D5E_zpsfisnvfi5.jpg http://i139.photobucket.com/albums/q299/I-W/Turbo/Turbo%20Drain/99F8996E-BB24-407A-B75C-18FAAE628ECD_zpsy8deonnh.jpg http://i139.photobucket.com/albums/q299/I-W/Turbo/Turbo%20Drain/873219F2-725E-4330-B2F1-48FA264126AE_zpsbhmii6te.jpg Link to comment Share on other sites More sharing options...
Turbo Cary Posted July 20, 2015 Report Share Posted July 20, 2015 Are the flange mounting holes the same? Link to comment Share on other sites More sharing options...
importwarrior Posted July 21, 2015 Author Report Share Posted July 21, 2015 Yes they are the same bolted it to 3 different T3 turbos to test fit.I will be going to drain to the Pan soon. But will probably use theFlexible Cummins turbo drain.http://www.enterpriseengine.com/wp-content/uploads/2012/05/1Ebay-003_15.jpg Link to comment Share on other sites More sharing options...
Skullzaflare Posted July 21, 2015 Report Share Posted July 21, 2015 Yes they are the same bolted it to 3 different T3 turbos to test fit.I will be going to drain to the Pan soon. But will probably use theFlexible Cummins turbo drain. ashttp://www.enterpriseengine.com/wp-content/uploads/2012/05/1Ebay-003_15.jpgi do know cummins drain is the same bolt pattern as every t3 Link to comment Share on other sites More sharing options...
importwarrior Posted July 21, 2015 Author Report Share Posted July 21, 2015 Have yet to find out the I-d of that drain tube . Link to comment Share on other sites More sharing options...
kidjc Posted July 21, 2015 Report Share Posted July 21, 2015 Nice! Good info Rob! (per usual) Link to comment Share on other sites More sharing options...
importwarrior Posted July 21, 2015 Author Report Share Posted July 21, 2015 the whole reason for this is that the turbonetics turbo i had blew the oil seals due to high oil pressure during cold startup.from what the turbo guy stated when i brought him my turbo for rebuild, the turbo drain was too small. he said to get the T6drain flange and go with a larger drain. and it would be better to go to the pan. so i am working on just that. Link to comment Share on other sites More sharing options...
lionbull Posted July 21, 2015 Report Share Posted July 21, 2015 the whole reason for this is that the turbonetics turbo i had blew the oil seals due to high oil pressure during cold startup.from what the turbo guy stated when i brought him my turbo for rebuild, the turbo drain was too small. he said to get the T6drain flange and go with a larger drain. and it would be better to go to the pan. so i am working on just that. Could have been crank case pressure not allowing proper drainage and pushing the oil back up too. Link to comment Share on other sites More sharing options...
kev Posted July 21, 2015 Report Share Posted July 21, 2015 Cool. Will be watching this thread. What type if fitting are you installing on your pan? I was looking at a no weld connection with a sloped entry. Such as ebay 181804940700 Kev Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted July 21, 2015 Report Share Posted July 21, 2015 cummins FTW Link to comment Share on other sites More sharing options...
importwarrior Posted July 21, 2015 Author Report Share Posted July 21, 2015 Cool. Will be watching this thread. What type if fitting are you installing on your pan? I was looking at a no weld connection with a sloped entry. Such as ebay 181804940700 Kev i was just going to easy route weld a barb on the pan real short rubber hose and 2 clamps. i just need to measure he lengthto the pan the good thing is that the turbo drain comes in a few sizes like 11 and 21 inch length. i just need to find the part numbers. the bad is that it can be up to or over $50 for the cumins drain tube. i am sure you could mill a piece of aluminum and make it a slip fit like it is meant to be.i just don't have any access to do such work. It fits a TON better but I did have to throw this gasket on there... https://genosgarage....?number=5264568 03-07 5.9L Cummins Turbo Drain Tube. 11-1/2" long.Cummins part # 3970875 21 Inch Long Turbo Drain Tube for 5.9L/6.7L Cummins Commonrail Trucks. Cummins part # 3934084 03-12 5.9L/6.7L Turbo Drain Tube Gasket. Cummins Part #5264568 . Link to comment Share on other sites More sharing options...
importwarrior Posted July 21, 2015 Author Report Share Posted July 21, 2015 good pics of it installed on a truck http://www.cumminsforum.com/forum/4th-gen-powertrain/450552-factory-upgraded-turbo-9.html page 7 had part numbers Link to comment Share on other sites More sharing options...
