- 29 replies
- 6456 views
- 11 replies
- 1055 views
- 27 replies
- 2790 views
Mopar Big Block
Mopar Baby
By IntercooledFlatty,
This 86' Flatty started out as an automatic car so the trans tunnel is a lil larger than the 5 speeds. After several 2.6l set up's i got really aggravated and decided this will be the V8 swap i've always wanted to do. The cross-member was altered as well as the oil pan, but the stock steering is all in place, for now, with plans later down the road to do a rack. The motor mounts are solid, the trans mount uses the stock brace altered with a 904 insulated mount. Shifter is a B&M hammer. Rear
Runs REALLY Rough when cold, fine when warm
By Squrlsquash,
On cold start it barely stays idling, sometimes tach drops to just above zero and the engine tries to die Light throttle input makes it worse (revs drop considerably) More throttle input eventually gets the revs to come up, but it goes back to bad idle if released After 5 mins or so when its warmed up it runs perfectly fine (idle is strong and light throttle revs just fine) Which temp sensor tells ecu when to richen for cold start? one on intake mani right by the thermostat housing has
2 interers for sale 1 maroon and 1 black
By markhansenconquest,
.post up what u need ...5 to 20 bucks sale.....maroon interior In grate shape from a garage kept car and the black interior from part outs last year......pair of 87 black seats 100 bucks....
