- 12 replies
- 1010 views
- 2045 views
- 54 replies
- 7028 views
88-89 engine wiring harness
By Ray-Ray,
i need the ecu to engine harness that goes through the radiatior suppport, in an unhacked condition please, pics would be great oh and a good 88-89 knock box if anyone has one
One Pass
Yet another OD Problem
By Lizzord30,
Well After changing to the new transmission(used with 94k on it) and doing the street valve body mod, it wont stay in OD under throttle. Like on the expressway can only have it stay in OD if i have like 5% or less throttle (not enof to maintain speed), I Checking fluid level is good. I have adjusted the vacume solenoid rod length to shorter and didnt effect the OD. Maybe my Solinoid is just bad I will replace with known good one (from my old trans) Would a that make it not stay into OD?
Intake mani, fuel pump, intercooler, & oem 7s
By StallionProject86,
Knock box, boost sensors, injectors, maf, translator, FCD, and radiator are gone. Added oem intake manifold to the list Intake manifold $60~under the assumption that shipping won't be to crazy OEM intercooler that has only seen 95k California miles $60 (2) Delphi 850 injectors $150, (2) stock style 850s $75 both sets have been flow tested recently with both in working order and clean Carter fuel pump with approximately 1000 miles on it. $80 Beck/Arnley fuel pressure regulator around 60
