- 725 views
- 4 replies
- 549 views
- 274 views
- 4 replies
- 511 views
Relay bad?
By BrokenquestTSI,
replaced all fuze links from DAD's website. headlights now pop up but i have no lights at all still. front and back. Relays is what i need to replace correct?
86 injectors wiring diagram
By starion revolution,
hi I have a 86 Starion but the injector connectors were cut, i got new connectors but i dont know wich wire goes into the conectors , does anyone have a pic or diagram for a 86, thank you.
88' Auto Range Selector linkage for Shifter
By kidjc,
Believe this is what I need: Park doesn't quite reach/line up, stay in park, popped out while warming up ! (you don't even wanta hear what resulted) Also, is not lining up in other gears, has caused shifting to not work properly, either shift points or Drive to go through all 3 shift points properly. Please correct if this linkage is known as something different. I have already done a few cleanups/workings on the trans, just another restarting point. Thanx!
E Brake cables
By kidjc,
Don't know if there's a difference... but (1) is for an Auto, the other a manual. 88'-89' Thanx!
