- 1505 views
- 4 replies
- 1564 views
- 815 views
- 1 reply
- 845 views
Which intake is better
By 88351wtsi,
Chad vs a modded Magna? If you had to choose between the 2 which one would you pick and how much would they be worth?
Springy/Squeaky Sound When Push Down the Clutch Pedal
By BoostedBimmer,
Ok, I'm not sure exactly what I should be looking for/diagnosing, but when I press down the clutch pedal all the way down and/or release it, it makes a springy noise (which I can also feel in my foot) at the point exactly when the clutch pedal is all the way down. It kind of feels like a rusty spring or something. Any idea what the problem may be? Do I need to grease anything? Other than the annoying noise it makes in-between shifts when I press the clutch pedal down, the car shifts fine a
Timing cover port BSPT or Metric
By lionbull,
Greetings, Does anyone know if the original return port for the turbo drain is BSPT or metric. I would like to put a plug there. Also is the original barb fitting aluminum? Thank you
How to connect the pos/neg wires on 3 wire O-2 sensor?
By Jest3r,
I did some research and found out where I need to connect the two white wires on my Bosch sensor. It looks like the existing wires have to be extended to make it to the positive 12v and the ground.. I can handle that, but when I get to the blue wire on the wiper motor how do I splice into it? The negative wire will just get extended.. Then will be capped so it can be screwed into the ground.. I think lol need a quick step by step and I can handle the rest.. As always your help is greatl
