- 24 replies
- 3468 views
- 1650 views
- 10 replies
- 1271 views
- 10 replies
- 1898 views
Porsche 924GTS Style Header Panel
By Guest Paul87Quest,
I am modifying a header panel to look like same panel on 924 turbos or 924GTS's. I figure it should bring in some more air....I still have some finish grinding to do as well as fit the actual 924 turbo grills into each location. I figure since our cars look very similar to the 944, that this mod may look good.
http://photos.yahoo.com/bc/i_8praisit/vwp?.dir=/My+Photo+Album&.src=ph&.dnm=headerpanel.jpg&.view=t&.done=http%3A//photos.yahoo.com/bc/i_8praisit/lst%3F%26.dir=/My%2BPh
Temp sensor controls auto. trans ?
By BaltTSI,
I replaced my temp gauge with a Cyberdyne digital gauge and had to disconect the the factory sensor ( the one on the right and below the thermostat ) and replaced the sensor itself . so now the auto trans won't go into overdrive , anyone know how to trick it so that it thinks theres still a hot sensor there ? 89 TSi
Having a digital gauge shows some very intresting temperature patterns , see my other post on them ( Digital temp. patterns )
Advancement
By BullShipper,
How hard do I need to wish to move up to 2 stars instead of a one 1 (newbie)
Solid OEM pulley for SDS
By Boosted_One,
I just received my solid pulley # MDO020842 (part# courtesy of KO) This pulley is not the pulley that is joined together with rubber.
I ordered it online from Conicelli Mitsu and it was $42.38 shipped.
This can be a one piece pulley. If run the AC you need to get an additional pulley that bolts into the crank pulley I listed via 6 bolts. Seeing I don't use AC I won't use the bolt in pulley.
It weighs 3.5lbs. I may need to get a shorter bolt but I see no initial install problems o
