- 39 replies
- 5363 views
- 16 replies
- 2328 views
- 6 replies
- 1859 views
- 918 views
255lph Walbro fuel pump
By Guest,
Well ladies and gentlemen I've been doing some research and have found that some of the higher output pumps made by Carter (Federal MOgul) are really Walbro pumps . The P72131 comes in a Carter box but has the Walbro stamp on the pump with part #GSL392 which in the Carter book only flows 55gph with a cut off psi of 190 . I called Walbro and they said that pump flows 255lph which is alot . I ordered one in and it is an inline pump with a 1/2" inlet and a banjo nipple on the outlet . The stock ban
DUAL INTERCOOLERS on an 87! pics!
By Adi,
I am in the prosess of fabbing in a second intercooler next to the stock one....I did some math and decided this should help cool the air about 25% more in addition to the cooling of the stocker. Â
I moved the radiator overflow to undernethe of the coil when in stock location...it rub gently against the a/c pump but no damage should occur. Â to the bottle of the pump. Â I removed the a/c fan from infront of the condensor. Â the bracket that holds it and the bracket that held the overflow can
tail light mod
By MainstreaM,
Ever wish all three bulbs in your tail lights blinked? It is possible with a new pigtail and bout 30 minutes. Here's how!
Materials:
crimps, butt connectors, small screwdriver, 10 mm socket and wratchet, universal pigtail-double contact Calterm part# 08512 any parts store should have this(Advance Auto does i work there), heavy duty or electronic(preferred) flasher
Directions:
1. unplug the wiring from the socket assembly. It is a small white clip on the assembly. take out the tail
True FAQ...
By Guest,
Since I all but created the FAQ for the largest S2000 website in the world I thought I'd offer a suggestion. No, I don't have a big head, but I care about stuff like this.
My idea for a Super-FAQ was never implemented there on S2Ki, maybe we could make use of it here...
Picture it like this, person comes to the home page, person is looking for info, person clicks on the "FAQ" and he/she sees a fullpage spread of the clear cutaway picture of the Starquest. You know the one, it's like you
