    pump gas magna dyno runs
    Boosted_One
    By Boosted_One,
    Ran the car on the dyno. I have 2 pulls up. One is at stock levels 9 psi. The other was 15 psi.   This was all on 93 pump gas.     http://a4.cpimg.com/image/D8/28/13286104-0f71-020000F6-.jpg   248.1 ft-lbs 197 HP   9 PSI       http://a5.cpimg.com/image/D9/28/13286105-45bc-020000F3-.jpg   340 ft-lbs 259 HP 15-16 PSI   This was the limits of the 93 octane pump gas. I did not run any race gas as I want to tune this for street use.   I made 2 runs at 18psi but it wasn't cutting it. I wa
    how do you install an third injector?
    Flat-body_Conquest
    By Flat-body_Conquest,
    I was wondering how someone would go about installing an third injector into an 1987 chrysler conquest?   Sean
    Even More mass air mods!!
    Lizzord30
    By Lizzord30,
    Well i was thinking this mass air i have makes the car running ritch becuse more air is going thought the mass air and geting sensored then before with the honey comb off. And with the bypass removed (connects turbo boot to air box lid) the car gets even more ritch, the bypass lets the air bypass the mass air and makes it not as ritch. with it removed it will make the car run even more ritch. So their has to be a way to make it a little less ritch. So i sliced off the top to let more air bypass
    Custom exhaust stock-type donut flex connection
    Rayman4449
    By Rayman4449,
    I'm sure not many folks will be interested in this creation but here is what I've come up with to recreate the stock flex connection in 2.5".  This is a TEP downpipe with custom 2.5 from there.  The exhaust pipe end with the flange has a short 2 1/4" pipe inside that the donut fits around and on to hold it in place.  What do you think?   http://home.kc.rr.com/rayman4449/dsc00892a.jpg http://home.kc.rr.com/rayman4449/dsc00893a.jpg http://home.kc.rr.com/rayman4449/dsc00894a.jpg
  • Today's Birthdays
    1. HxC_zombie6
      HxC_zombie6
      (39 years old)
    No members to show
