- 9 replies
- 2166 views
- 4 replies
- 3929 views
- 7 replies
- 10207 views
- 1073 views
Wiper motor, linkage, intermittent, door locks
By madmanperez,
Here's another one I can't get my head around. This winter has been a little colder than most (central Florida not know for freezing temps), What I've noticed is my front wipers won't do a full sweep. They pause on the way up, sit there then go a little further, pause again then park and start all over again. Only on intermittent setting. On regular they go full sweep up and down but when you go to turn them off the switch momentary goes thru the intermittent setting and you don't get a complete
1987 Mitsubishi Starion
By ClassicMan,
Selling my 1987 Mitsubishi Starion turbo really nice interior a few dents and things on the outside but not bad, put a new battery and everything comes on as normal but the car has been sitting since 2009 and the engine seems like it’s seized but I see no reason it cannot be tapped free, it’s an automatic champagne exterior black interior had new keys made for it everything is there. The car is located in Signal Hill California
selling for 3500 or best offer
Pierre 56275351304 enquirie
Car Won’t Start – But Has Good Compression, Spark and Fuel
By Alpina_Blue,
Hey guys, my '87 Starion has hit a bit of a brick wall and I'm hoping someone on the forum might be able to shed some light. A local shop has been meticulously going through the car, replacing and servicing everything as needed with no real issues to date. However, just as things were wrapping up, it suddenly won’t start for no obvious reason.
Here are some basics that I know:
1. The car will crank, but won't start
2. It has compression, fuel and spark (compression is great across
Leftover jet-valve head, what do
By GoldStar,
Some time back, I replaced my head as the cam caps had developed stress fractures. I now have a jet-valve head taking up precious space in my garage, as well as another set of cam caps/rocker arms/rockers that I naively thought I could just swap with the cracked ones. Was thinking about just scrapping it all since it looks like G54B heads are still being produced, but I wanted to get a second opinion before I did. What should I do with it?
It does have the jet-valve delete kit, but it definite
