- 648 views
- 437 views
- 470 views
- 474 views
Mazda TPS adapter
By dtownmikebrown,
I found a TPS from a late 90's 2.0L Mazda 626 at a local salvage yard. I've read that with a little bit of fabrication they can be good cheap replacements for the OEM version, so I'm gonna pick it up. I know there is at least one vendor that sell nice adapter plates, but I'm on a tight budget right now. Has anyone had any luck making an adapter or seen a good how-to guide?
1989 6 bolts axles
By JohnnyWadd,
Here is a set of axles . 1989 6 BOLT. Automatic car. These had zero play and good boots and vey tight. I took them apart to rebuild. There are sandblasted clean. Fully inspected and in awesome shape. These need reassembled and come with the high quality OE type boots and grease and clamps. Shipping them disassembled to fit in a flat rate box. $200 shipped. http://i1187.photobucket.com/albums/z388/starionkiller/parts%20for%20sale/th_20140515_222407.jpg http://i1187.photobucket.com/albums/z3
Block Salvagable?
By Leonard Catanzaro,
Broken head block in block. Previous owner tried to drill out bolt and did-offset and into deck. If it makes any difference, between 2nd and 3rd cylinders. Is block salvagable? Want to use head studs and 15 lbs boost. Is this block repairable. Looked good otherwise. Thanks in advance for your input -Lenny
Need a 1988 Conquest sunroof
By Skt1988Conquest,
My sunroof seal around the glass is crusted up because the previous owner left it in the sun.
