- 8 replies
- 1305 views
- 7 replies
- 1398 views
- 80 replies
- 13598 views
- 1 reply
- 1174 views
Windshield washer pump replacement -Front
By Gregster1234,
What is necessary to remove and replace the pump. It looks like the battery then maybe the tank?
Car won’t shut off!
By shortybangb,
Hey friends! My 86 Starion won’t shut off when I take the keys out the ignition, I have a good batt, fuse links near batt are good and my alternator is good I am not sure what it could be, any help would be great thanks! Cheers! 👍🏽
The start of my ford 5.0 T5 swap and restoration
By BKB94,
This has been something I have been planning for about 25 years and I guess I'm finally ready to start it. I pulled my front clip in with my home made tractor for mock up of the 5.0, T5 trans, and rack and pinion. Sounds good and dead nuts reliable is the plan, will probably be around 300 RWHP. I have rack & Pinion I will be installing after I map out factory steering box bump steer and ackerman. I will be using a lot of the mustang factory wiring harness to control A/C, Fan, Engine. As I p
84 Conquest parts car available
By blk84,
I have a 1984 Conquest parts car that is available for anyone who can pick it up in a fairly short period of time. Car currently has no motor in it but those parts are available separately. Car is at a mechanics garage at the moment and they need it moved fairly quickly so I'm posting this up in the event someone has an interest and can grab it before I send it to a salvage yard or recycling. Car is located in Connelly Springs, NC and would require a flat bed or trailer to move as the tires a
