- 24 replies
- 1720 views
- 8 replies
- 880 views
- 4 replies
- 440 views
- 634 views
Something went bang?
By StarquestRescue,
Act pressure plate 1 shift fork zero. It broke right in front of my house after being 20 miles from home. http://i237.photobucket.com/albums/ff45/StarquestRescue/Damaged%20parts/DSC03479_zps70a79959.jpg
low rpm,s when running A/C
By chassispuke,
car idles fine when not running a/c. but rpm,s drop instead of going up when i use my a/c. it drops down to about 600 or less. my other two cars do the opposite they run about 1100 to 1200 rpm,s at idle. any suggestion are greatly appreciated. thanx edgar
Is this salvagable
By stoopideric,
I started pulling my motor apart today and I found this crack across 2 water passages and 1 head bolt hole. It doesn't go down into the threads and I don't see any sign of water leaks. Opinions?
Very rich at low throttle and flooded at start-up
By movin on,
My car: 89 650/950 walbro 255. 292/280 cam mechanical. My issue is that as soon as I am moving and touch the gas. It instantly drops to 10:1 AFR and bogs. It does with a stock MAF, 1g, and a Maf-t. I tried to tune around it thinking it might be an excess of fuel from the cam duration, but have seen just a little difference. I reset and tested my TPS and my MPS is good. The rest of the fuel curve is just fine, including idle. 2nd issue, and might be related. My car appears to flood it
