- 482 views
- 41 replies
- 4623 views
- 1042 views
- 4 replies
- 785 views
Fuel not sucking?
By station,
Hi! I've reinstalled the fuelling system in my Starion. I was trouble shooting over why I wasn't getting any fuel, and to cut a long story short, I found the pick up wasn't sucking any fuel into the pump. I removed the pipe and jigged up a mini fuel reservoir with petrol in in a jug and the car ran fine. Is there any reason why the pipe wouldn't be getting any fuel - does the tank need to be at least partly full? I put about 12 litres of fuel in, which I think should be enough. The strainer di
GP Flexible Power Steering Lines $175
By Funky Phil,
FunkLab Flexible Power Steering Lines! Need 10 orders to hold price. High Pressure, Steel braided Line with steel ends and fittings -PTFE lined and clear coated $95 shipped Low Pressure, Steel braided Line with steel ends and steel fitting -PTFE lined and clear coated $90 shipped Both Lines together $175 shipped. **PM ME FOR PAYPAL INFO** New version of the low pressure line ships tomorrow for test fitting and pics. This will match the current high pressure line. Pricing is solid. Po
Wasn't this a SQC member's car???
By dmdvzla,
http://www.ebay.com/itm/Plymouth-Other-Hatchback-2-Door-1985-conquest-restomod-300-hp-street-legal-pristine-condition-show-/201184969819?forcerrptr=true&hash=item2ed78f045b&item=201184969819&pt=US_Cars_Trucks
Aftermarket Speedo & Tach light wiring
By mstieg,
All the other gauges have separate bulbs with W & Bl wires that go into our grounded dimming circuit no prob. My Autometer Tach & Speedo has Power, Light, and Ground among others, so...DO I go with the regular ground OR the dimmer ground? I'm assuming standard ground so it'll operate normally & figure the lighting might just not fade w/ dimmer?
