- 9 replies
- 809 views
- 12 replies
- 1116 views
- 608 views
- 9 replies
- 764 views
HKS No Longer Supports Us??
By psu_Crash,
Well, looking through some things on their website I see this. http://www.hks-power.co.jp/usa/products/Pid=671.html So apparently they do this sell ONE product that is designed specifically for us! I'm curious as to what this "Install Kit" contains. I installed my EVC without a kit and it wasn't rocket science
To rich at startup
By hunter85,
I picked up another conquest and it runs good when you get it started. Ok after the first start of the day its fine but if you dont crank the car as soon as you turn the key {IE leave the acc on to listen to radio, set tps, ect} and dont crank the starter it will flood the plugs and not start I know because I can uplug the primary injector and it will run for 10 secs off the gas its dumping into it , plug the injector back in good to go. I checked my oil and it looked amber but had a little gas
Tie rod adjusting sleeve
By JLOPEZ,
Need a driver side tie rod adjusting sleeve with tie rod ends.
need new battery
By randy,
I need to purchase a new battery for my conquest, should I opt for one from sears,or Walmart brand or any other? Also what series batteries are you using?
