- 7 replies
- 1372 views
- 1 reply
- 677 views
- 13 replies
- 2649 views
Wtb 950cc (green) injector
Wtb Fuel level sending unit
By Chino710,
Need a fuel level sending unit mine cannot be saved. Would also take the fuel pick up unit but mainly need the sending unit. TIA
Struts Question
By Contsi,
I believe these are NLA but can parts be found to rebuild?
Also, how to tell if you have Hydraulic or Gas damper type?
Thanks
Front Wheel Bearing/Seal Replacent
By Contsi,
Having rubbing type noise when coming to a stop; not continuous but per each revolution and doesn't appear to be every time.
Appears to be coming from right front wheel. Does not appear to be related to the brakes.
I got a set of inner, outer bearing an seal and thinking of replacing.
Manual shows special tool for pressing the race. Is this something I can get? and how tricky is this project?
Had a bit of play to that wheel a couple years ago, I tighten the hub nut a bit and
