TSi2555
Everything posted by TSi2555
Happy Birthday Shelby, Hope You have a Wonderful Day!!! David
check your radiator hoses, if they aren't ribbed or have a spring in them? they may suck flat when you run more RPM than idle keeping your coolant from circulating. I've seen it happen. (check when at operating temp)
A Bald Head Is Actually A Solar Panel For A Love Machine :hug:
Happy Birthday Shelby, Hope You Had An Enjoyable Day!!!
Hmmph, Maybe your low on turn signal fluid :rolleye0018:
Is it smoke or steam vapor? get your nose in it the next time you see it, you may have a leaking ( shudder ) heater core.
1957 Mercury Montclair 2door hardtop, cruiser skirts, 368 cubic inch turnpike cruiser engine. Man what a Ride!
1987 built; July 1986 Serial # 009456.
I had this happen to me, after checking the switches, they were ok, I ended up having to run another wire from the driver side to pass side, the same wire, power , that JAinsworth is talking about, also you might ck. the conectors this wire runs through. Good Luck.
anyone ever installed a powerfc?
TSi2555 replied to speedyquest's topic in Advanced Virtual Mechanic
Hi Speedyquest, Do you have that small tube in the accordian hose plugged? -
Yes, it was working fine on the pass. side but not on driver side, I got another box off e-bay and swapped it out and everything worked fine, both sides, I plugged the old box back to see if it was a plug issue but it wasn,t. Good Luck. David
Hi DAD, I had the same trouble , after checking out all the "easy stuff" I had to replace the Automatic seat belt control unit behind the radio, that took care of my problem ,what a job.
Thanks for your help everyone.
Hi does anyone know the part # for the 3 wire o2 sensor that screws in to Kellys 2 1/2" down pipe? Thanks for your help. Bosch #
at the bottom of page 8-48 there's a wiring diagram and it shows a wire going from the ECI relay to the fuel pump, its located on the pass. side behind the kick panel, is that what your looking for :confused0024:
Didn't someone design a hood strut setup for starquests a while back, or did I have another flashback :aj:
Thanks Jimmy :thumbsup:
I'm looking for that also :confused0024:
Did you have to Lay on your back on the door jam and do this :lightingzapA:#**%##&@$$!!!!
I just got here, This sight is Beautiful!! Great Job Ryddler!! I Love the New Stuff!!!
I got just what I needed from Eric, Great To Deal With,With Very Reasonable Prices, Packaged Very Well for Shipping, If the need arises I'll Deal With Him Again, Thanks Eric. TSi2555 David
Eric, PMed and E-mailed You
TTT
