shae201
Video editing, playing guitar, home theater and restoring my conquest
Georgetown, Kentucky
Website URL
http://
40324
Polar White
Dark Red
shae201's Achievements
for an 87 btw
I need the headlight switches that go on both sides of odometer hood. To clarify both sides that each have 3 switches.
Will tps throttle sensor #th248 work for 87 quest manual w/turbo?
Need a TPS for 87 quest used or new. Thanks
Yes I used a noid light.
Im not getting Pulse or signal to fuel injectors. Replaced injector clips about 4 months ago. Replaced coil inside distributor and ignition coil. Do not know what else it could be.
I have put on a brand new Fuel Press Regltr and alligned the fuel filter bolt hole to the hose out of top of fuel filter and both locations are still leaking fuel. both seals are there on top of regulator and there is a copper washer below fuel hose loop and one that seats underneath bolt but filter continues to leak out of top like crazy, just don't know?
Im leaking where the fuel pressure regulator screws into the injector mixing unit. I put my new regulator from Beck Arnley and screwed it as tight as possible and it is spraying gas out the side. Is there orings that go into the injector housing?
It's actually leaking where the regulator connects to the housing, will try to figure it out this weekend.
Thanks, bought one from Rockauto.com (Beck Arnley) $80 bucks.
My FPR is leaking from bottom end where vacuum line connects to it. Does that mean an internal leak Im guessing? Is it safe to order one from advance or autozone or does it need to be OEM part? And also, can that prevent your car from starting? Thanks any help is appreciated
Previous owner used electrical tape to hold wires together inside distributor which caused an arc. Now I have to replace everything that owner did wrong.
Nevermind, found bwd brand from advance auto.
Trying to find a distributor pickup kit for 87 turbo quest. Oreileys has one but said its for single plate and not dual plate. Is that the right one? Does anyone know what he is talking about?
