Power ram 50 turbo
Everything posted by Power ram 50 turbo
Manual 5 speed transmission.
Power ram 50 turbo replied to Power ram 50 turbo's topic in Items Wanted
How much I can drive over and pick up -
I'm in Indiana -
Looking for a 5 speed manual transmission it's not going into a quest but a 86 power ram 50 4x4 I believe it's the same transmission but have to switch the tail shaft my truck has a mpi 2.6 need something in good shape no noise let me know what you have thanks
Ya I don't remember this site iv been a member since 2011
What a surprise I didn't expect to see the new site when I logged in I think I liked the old one better but glad it's still around but I'm back to being a newbie .
Why bother with a rant if you want to leave. Just do so no one will miss you anyhow.
A little superglue and duck tape and she's good to go lol.
"Complete turbo package"
Power ram 50 turbo replied to 88351wtsi's topic in eBay/ Craiglist notices and alerts
I wouldn't waste money on it the turbo won't last long the header will crack it's all cheep Chinese knockoffs you may get a thousand miles out of the turbo. -
Happy birthday have a great day.
Happy birthday bud have a great day.
I've been running them for years best advice I can give you if you plane on running one is keep the line away from any heat and keep them straight and use nylon retainers to hold them in place iv never had one fail on me and have used them for about 30 years just takes good planning even copper can fail if installed wrong .
turbonetics delta mark 2 wastegate problem
Power ram 50 turbo replied to Power ram 50 turbo's topic in Virtual Mechanic
Thanks I'll give this a try -
I'm having troubles with my turbonetics external wastegate over boosting won't open I have a 9 to 13 lbs spring in it and it's boosting 30lbs so the question is how do I hook the vacuum lines to it I'm pulling the reference from the turbo compressor side. on the wastegate I have two ports one is vacuum the second is boost I tried it many different ways and it's still over boosting I took it apart and checked the diaphragm and it's good if any of you guys have any info on this wastegate or is running one any help would be appreciated thanks
happy birthday FREEBIRD
Power ram 50 turbo replied to markhansenconquest's topic in Just plain ol' B.S.
happy birthday Jason have a great day. -
knocking from back of engine on acceleration
Power ram 50 turbo replied to 88starchris's topic in Newbie Question and Answers
it sounds like you spun a bearing or at least one that worn out I would drain you're oil and inspect it for metal shaving. -
Just info you need to set a price site rules glws.
happy birthday SHELBY !!!!!!!
Happy birthday Shelby have a great day and hope you're doing well. -
stock intake for mpi anyone have any luck
Power ram 50 turbo replied to Power ram 50 turbo's topic in Just plain ol' B.S.
Thanks I appreciate all the input now to get started. -
StarquestRescue that's exactly what I was thinking lol. -
Thanks Scott I planned to run you system . -
Tuning not the problem and I have access to a dyno and I'm not looking to put 400hp if I can just get somewhere close to 300 would make day so just wondering if the stock is capable as a mpi set can do it I can modify my intake for around 100 bucks I have all the parts to do it rather not spend 500to 800 hundred if I can get the hp I'm after and I know you can make great power on tb but not when the engine is in a 4x4 truck the best dyno run I had with it was 228hp not bad for a 4x4 -
As the title says any one use the stock intake as an mip setup and got any real power from it I'm thinking about modifying mine but wanted to see if it's worth it thanks for your in put.
How much for the maft set up if you are willing to split up thanks.
I have an 86 ram 50 Gen 1 4x4 I did a turbo swap to 5yrs a go it's pictured below the motor wasn't a stock build last time I dyno it she put down 228hp to the wheels and I can tell you the transmission will hold up just fine I don't think you would have any trouble out of montero transmission .
Does anybody know what the deck height is on a g54
Power ram 50 turbo replied to questtuner82's topic in Virtual Mechanic
And the same guy that claims he tuned his tbi quest and makes 535hp
