drift_king
drift_king last won the day on July 22 2015
drift_king had the most liked content!
About drift_king
- Birthday 11/21/1992
bristol, RI
02809
1986
Valencia Gold
Being Modded
drift_king's Achievements
i have a trans you can have in rhode island but you have to pick it up
Eveerybody says that no one is forcing you to be here, your right ill be leaving soon, and people wonder why these cars are dying out, its because the comunity sucks. that mentality, that eliteist attitude.
first off let me start by saying it al ready has all the oil lines for the stock locations in -an and stainless steel. vibran tlines and fittings. the manifold was made by a tuning shop called dyno tech tuning famous for the welding and dsm cars. the header is fully tigged t304 and 1000 horsepower capable. its a 63.60 turbo garret m10 capable of 400 horse power. @20 psi . its ecternally gated and i have a tial 38mm wastegate to go with it. for a bit more, of you could grab your own. it has a three inch downpipe i will include that has been heat wrapped. the manifold has a lifetime warranty through dynotech so if you ever have any issues they will fix it, but it very high quality. i paid 1900 for the manifold waste gate and downpipe and id be willing to sell it to you for 800 http://imgur.com/a/gaxA7
I cant stand this comunity of SQ's. everybody os so cheap and overly critical, its no wonder these cars suck . the people who own them suck. everybody wants something for free, or they want a 500 hp car for 50 bucks.
What it has. Aeromotive inline fuel filter with -6 fittings Aeromotive 1000 fpr set up with fittings for mpi All fuel lines from tank to return with fittings. SOLD Walbro 255 SOLD Full plug and play no work required mpi harness with locked out dizzy and Msd box. literally connect the power and rip burnouts. Complete with fuse panel, and relays . coolant relays wired in. 300 Full 304ss equal length tubular header with 63. 60. Gnx turbo oil lines and down pipe. And tial 38 mm waste gate with ten psi spring and air intake SOLD Matching 3 inch exhaust as one piece with borla straight thru muffler 500 Aem wideband and sunpro boost gauge SOLD Unorthodox racing pulley SOLD PS pump altinator 50 Full front mount 2.5 inch with greddy evo 10 core for TBI or mpi whichever you choose SOLD Hydraulic hand brake setup CNC handle and ssbc prop valve Motor with 292 cam and fresh head plus gasket. arp head studs New timing chains bse. 700 89 transmission with competition 19lb flywheel and three puck clutch 500 Take motor and teanny together for 1000 Authentic austrialian 4g63 83 hood. 500 H4 headlight conversion SOLD 4 88k shp struts 200 4 245 225 50 16 prime wells mounted and balances on 8" rims 2 7 inch rims and a 9 inch rim 20 new mcgaurd lug nuts -6 an ss lines for cnc catch can custom made SOLD A full black interior with mint 87 seats worn 89 seats 100 Full race vacuum manifold for mpi setup mounted 30 5 quarts of bradpenn break in ol i was offered 150 scrap for the car lets get everythng sold on this thing so the scrap yard doesnt get it. you can reach me at eugenechurch1992@gmail.com funk ss powering lines never used 120 http://imgur.com/1ZMxAhb http://imgur.com/Zx1uSWS http://imgur.com/LyHH5mt http://imgur.com/JaAuwgf http://imgur.com/hejnG7Y http://imgur.com/idLvjWu http://imgur.com/x5tBkA3 http://imgur.com/JUe7jEl http://imgur.com/FOG2MOs http://imgur.com/04HYlxG http://imgur.com/6XAjFfZ http://imgur.com/wbTFkxQ http://imgur.com/U5d2bxK http://imgur.com/38EO54C http://imgur.com/afX0l4t http://imgur.com/mYIf7SM http://imgur.com/6Nvc6LM http://imgur.com/TsuSo6W http://imgur.com/jZmqhhD http://imgur.com/NTXFrQf http://imgur.com/I8i6PEy http://imgur.com/mvHzqR8 http://imgur.com/etHwUN0 Location is RI 02809
I guess i screwed the pooch again
drift_king replied to drift_king's topic in MPI/Standalone Trials and Tribulations
Update : tried jumping the intake ground to somewhere else and it didn't help. It seems like the ecu gives me signal while probeing the back of the harness. But won't give me any signals at the sensors. Plus today I found that I'm getting ground from my tps's 5v wire. I think the connector that I got from the junkyard might be bad. Could a bad tps plug make the ecu not power on? When I probe the back of the harness plug on the ecu it has the injectors getting power. But when I probe the injector clips they have no power. How could that be? As for wiring I changed I added two injectors with fuses. I rewired the tps to a Ford tps. I moved the intake ground. I'll get back to it tomorrow night. I'm beat and tired as a dog right now. I'm out of options right now tho. I can't bring it back to the speed shop they charge me 100$ an hour and hack the car up so bad. -
I can't understand why the fuse panel is powering everything but the ground on the intake manifold is not showing anything on my test light... I have the problem pinned down to that ground. -
http://i.imgur.com/rEaTkno.jpg Can anybody confirm or deny the way I have the tps wires labeled? -
Sup boys quick update. I checked for power on the megasquirt pin 28 has power. I checked all the fuses and they have power also. My ign coil tps and I injectors have no power. The ground that's supposed to attach to the intake has no ground signal. The main relay has power and ground also. I worked a little longer and I believe I wired my tps wrong or my ground to intake is wrong. -
Okay nice I decided against parting my car out. You have a Valencia gold quest?
